    Dynamic Components
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 3 Posters 1.6k Views 3 Watching
      Arslan
      Hello,
      Please take a look at the attached jpeg files, look at them in order as it was supposed to be a movie but this forum does not accept .avi files. It was done using Solidworks, I’m wondering if SketchUp is able to create something like this with a dynamic component where in the model if I rotate one part (as in the pictures) along the bottom axis and another part is connected to the top, it will move with that part without skewing like with nodes in planes.
      Arslan
        remus
        This should be possible, although the maths is going to be a little tricky, i think.
        I'll try and knock up a little demo this evening πŸ‘
        edit: sorry, its going to have to wait a little longer. Too much stuff to do.
          Seems you will have some slidding rubbing frictions πŸ˜„
          Seems one piece must place behind? πŸ˜‰
            Arslan
            Not too worried about friction right now, its a bracket for a solar panel and I just want to be able to move it around that way since it will be tracking the sun. I also need to do some shading studies so it would be great if this could move like that so i do not need to create a new bracket every time.
            Arslan
              remus
              Here you go. Just to warn you, its pretty rough around the edges. The maths was a little trickier than I had anticipated.
              To set the angle: right click->dynamic components->component options.
              you should be able to change the geometry within each component fairly easily, as long as you bear in mind where the centres of rotation are for each piece.
              adjusting sliding thing DC.skp
                Arslan
                Thanks remus, this will be a good starting point for me to make a full dynamic solar panel.
                Arslan
