Other way to make this?
I watched the car tutorial in sketchucation tutorials, and now Im doing my own car project.
But I'm getting tired of making the faces from lines like in the hood.
What Im doing is similiar to this:
Is there any other way to do this faster with the same result?
PS: Sry for my possible bad english
For one raw Try Projection_v6 by Didier Bur
Or for all the curves in the same time Simple Loft by Chris Fullmer
(but you must click curve after curve for give the order!
Then make a "clean selection"You really helped me. Thank you for the fast answer.
Not so faster because you don't seen the image posted
So see my previous post again
Then make a clean selection by architectboy or cleanup_model.rb by J.H. Aughey
Cick image for see all !
Edit: NVM. The differences betwen those scripts are Need to weld and not arent?
Exactly
Projection works directly on your drawing no need to weld your curves, just select one curve and make the "projection" along the vector, then select new curve etc...Simple Loft works only with curves welded (so each curves must be welded separately) make your loft then explode the result at the end
for the 2 plugs curves must have same number of points!
Even the Sandbox from Contours tool should work OK with curves like these.
Anssi
Anssi
NO, it screw up it.
Thank you guys, I choosed loft plugin
