    Other way to make this?
    8 Posts 3 Posters 796 Views 3 Watching
    • G
      Goldragon979
      I watched the car tutorial in sketchucation tutorials, and now Im doing my own car project.
      But I'm getting tired of making the faces from lines like in the hood.
      What Im doing is similiar to this:
      Is there any other way to do this faster with the same result?
      PS: Sry for my possible bad english
      • G
        Goldragon979
        For one raw Try Projection_v6 by Didier Bur πŸ˜‰
        Or for all the curves in the same time Simple Loft by Chris Fullmer πŸ˜‰
        (but you must click curve after curve for give the order! πŸ˜’
        Then make a "clean selection"
        You really helped me. Thank you for the fast answer.
          Not so faster because you don't seen the image posted πŸ’š
          So see my previous post again πŸ˜„
            Then make a clean selection by architectboy or cleanup_model.rb by J.H. Aughey
            Cick image for see all !
            • G
              Goldragon979
              Edit: NVM. The differences betwen those scripts are Need to weld and not arent?
                Exactly πŸ˜‰
                Projection works directly on your drawing no need to weld your curves, just select one curve and make the "projection" along the vector, then select new curve etc...
                Simple Loft works only with curves welded (so each curves must be welded separately) make your loft then explode the result at the end πŸ˜‰
                for the 2 plugs curves must have same number of points!
                • AnssiA
                  Anssi
                  Even the Sandbox from Contours tool should work OK with curves like these.
                  Anssi
                  • G
                    Goldragon979
                    Anssi
                    NO, it screw up it.
                    Thank you guys, I choosed loft plugin πŸ˜‰
