    Making a SketchUp tool - incorporating the mouse & keyboard
    55 Posts 6 Posters 3.8k Views 6 Watching
      BTM
      Okay πŸ‘
      Man, I've got a LOT to learn πŸ˜†
        BTM
        ` require "sketchup.rb"
        class Pinchmover
        	def activate
        	@model = Sketchup.active_model
        	@ent = @model.entities
        	@view = @model.active_view
        	@slct = @model.selection
        	@slct.clear
        	def onLButtonUp(flags, x, y, view)
        	ip = view.inputpoint x,y
        	pt = ip.position
        	pt2 = Geom::Point3d.new pt
        	@cpoint = @ent.add_cpoint pt2
        plugins_menu = UI.menu("Plugins")
        item = plugins_menu.add_item("Pinch Mover") {
        Sketchup.active_model.select_tool Pinchmover.new
        I like mouse interaction and inferencing better than a dumb little inputbox πŸ’š
        ... Now to get it to make only ONE cont.point ...
        ... And THEN a way to select an endpoint for the tool to use as the centerpoint of the pinch πŸ˜’
          BTM
          ; But now I think I know how to tackle both issues at once 😎
          • Chris FullmerC Offline
            Hey, that's great! Its adding the construction point really well. Once its added, you have its position so you know where the pinch is going to. The second cpoint should indicate the vertex to be used.
            I agree, you have to figure out those things, so I'm interested to hear how you do it!
              That works great! You have two separate points defined and stored for later use. Perfect. Now you have to decide how you want your script to move forward. Does it just begin automatically once the 2nd construction point is set? Or does it pop up a radius input box immediately after the 2nd point is added. Or does it just sit there until the user hits enter? Once they hit enter then it beings running. etc.
              So far so good. You've gotten past much of the mouse implementation. Now its on to transformations! WooHoo!
                BTM
                **` require "sketchup.rb"
                class Pinchmover
                	def activate
                	@ip = Sketchup::InputPoint.new
                	@slct.clear
                	@first = 0
                	@second = 0
                		if @first == 0
                		ip1 = view.inputpoint x,y
                		pt1 = ip1.position
                		pt2 = Geom::Point3d.new pt1
                		@first = 1
                		@second = 1
                		elsif @second == 1
                		ip2 = view.inputpoint x,y
                		pt3 = ip2.position
                		pt4 = Geom::Point3d.new pt3
                		@cpoint2 = @ent.add_cpoint pt4
                		@second = 2
                	def onReturn(view) #Unnecessary, I just want to see if it's working.
                	UI.messagebox @cpoint
                	UI.messagebox @cpoint2
                πŸ˜„
                ... So?
                  BTM
                  I edited that last post about 30 seconds ago, so that it would have different variables to repeat. I don't know if it'll help, but I thought it would be a good idea.
                  • ely862meE Offline
                    ely862me
                    i don t know where to ask so i ll ask here...is there any chance to make a small code or plugin for deselecting a line or something else without zooming out and click away from model..
                    i was thinking to rewrite the esc key sketchup function (..if u are in a group or is selected a group by pressing esc the group is deselected or is closed )...i would like by hitting the esc key to deselect the selected geometry
                    Sorry for bad phrases πŸ˜„
                    Elisei
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      You can go ahead and start a new thread generally for questions like that... πŸ˜„
                      The answer is ctrl-t. Deselect is already built into SketchUp, and that is the default shortcut key. If it doesn't work, then you've probably mapped it to something else. Go re-map it to they key that you want.
                        BTM
                        Well, first of all, the plugin would be easy. Unfortunately though, you'd have to add a shortcut key to cet plugin, because, as far as I know, plugins seem to work only when they are in use. Unless it's somehow possible with initialize. πŸ˜•
                        • ely862meE Offline
                          ely862me
                          U re the MAN ..it works..
                          I asked some time ago and the answer was zooming out and click away..
                          Thanks for the tip..
                          Btw you are doing a great job with all these plugins ..Thanks for that too!
                          Elisei
                            BTM
                            ... For me, shift alt a.
                              BTM
                              Okay. Here's my big issue, I knew I'd end up having.
                              this is the part I added to the end of the elsif in onLButtonUp:
                              prompts = ["Radius="] defaults = [ 0.0.to_l] list = [""] results = UI.inputbox prompts, defaults, list, "Please input desired radius." @rad= results
                              Now, HOW can I go through all the active points in the model**(to see which ones are within the distance of @rad from @cpoint2 in the future)**? I can't use .typename, because endpoints aren't really entities, so I'm stuck.
                                This is what I use to iterate through a model for vertices.
                                ents = Sketchup.active_model.active_entities
                                verts = []
                                ents.each do |e|
                                 if e.typename == "Edge"
                                  verts << e.start
                                  verts << e.end
                                verts.uniq!
                                That adds every start vert and every end vert to the array, then .uniq! removes all duplicates.
                                Now you have an array of all vertices in an array. This is the transformation method you will need to use in this script:
                                http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#transform_by_vectors
                                There's lots of ways to transform things, but most of them transform one object at a time, which won't work for what your doing (I don't think it will at least). So this transform is cool because it does it all at once. What you need to create is an array of vectors that correspond to your array of vertices. The vector should be the vector that your vertex will move. Hope that helps with the next step,
                                  BTM
                                  Ah, thanks for that! πŸ˜„ I don't see why google doesn't just add a method in entities for vertices (Or whatever they're called, points). Heck, they should have it so you can select them with the selection tool IMHO. Anyways, thanks again; I would have been ages trying to figure that out πŸ˜†
                                    Have you ever used the Set class to keep track of objects? http://code.google.com/apis/sketchup/docs/ourdoc/set.html
                                    I haven't, but I have a feeling it could be useful for this as it's supposed to only allow unique objects in the list.
                                      Oh really? That's cool. I have used it once in a script, but I didn't realize it would not allow duplicates.
                                      I'm going to go read through that Class again. Sounds like it might be more helpful than I had realized. Thanks Thom,
                                        BTM
                                        ... Just found another problem πŸ˜’
                                        How do you turn @rad, which ends up as an array with the length in inches in it, back into a length?
                                        i.e. @rad = results.to_l doesn't work.
                                          That's what I was saying was the problem in that first bit of script you showed - you can't vconvert an array to_i, or to_l. I'm not sure why it was working on your end. Its ok though, its an easy solution.
                                          So results is an array of whatever was in the inputbox. In that array, the radius is in the zero position. So when you save @rad, just convert it to a length:
                                          @rad = results[0].to_l
                                          Now @rad is not an array. Its just a length. Hope that helps,
                                            BTM
                                            [0]. πŸ‘Š Man, I KNEW it was going to be something completely obvious. The first item in the array! Why can't I think of these things! πŸ˜†
                                            • 2 / 3
