    Making a SketchUp tool - incorporating the mouse & keyboard
    55 Posts 6 Posters 6.0k Views 6 Watching
    • Chris FullmerC
      Excellent πŸ˜„
      • B
        BTM
        ... Now I need to figure out where in the class to put that πŸ˜’ . I'm still not that fond of what defs do what exactly.
        • Chris FullmerC
          I think you'll probably put it in its own method.
          If you want it to be the first thing run every time the user begins the script, then you can call that method at the bottom of the activate method.
          And then call other methods from the onReturn method probably (though onLbuttonUp is common too). So it works like this, if you want your script to advance when the user hits enter, then call all YOUR methods from the onReturn method. It only gets triggered when the user hits enter/return. So only call your method from within onReturn and it will only get run once they hit enter. Here's an example of how it could flow
          Your "add cpoint" method gets run from the activate method because that is run everytime the user starts the tool. So that will run your construction point right off the bat. Then the user should click on a vertex to specify that vertex as the center of operations. So you would have code in the onLbuttonUp method that yould trigger when they click the mouse. It should take the InputPoint and store it as some @centerPoint variable, assuming its a vertex they clicked on).
          Once the cpoint is set and the centerpoint is selected, you could pop up a UI.inputbox asking what radius to use. When they hit enter, then you run a method that does all the calculation and drawing/transforming.
          The way I described it there did not require the user to hit enter, so all that would be run from the onLButtonUp method then.
          Seriously a tool with the mouse, and with transformations. Nearly as hard as it gets, but do-able. Good luck!
          • B
            BTM
            One problem i'm having is not knowing what to enter in the grayed in area. I thought that Pinchmover, the name of the class, would work, but it doesn't. What does?
            I put in a bunch of variables at the start, just incase I'll need them, so I won't forget what they are.
            • Chris FullmerC
              Sketchup.active_model.select_tool Pinchmover.new
              And you will also need to move that to the bottom of the script. You can't instantiate the class until after it has been defined. Just put all your menu work at the bottom of the script.
              • Chris FullmerC
                Just the name of the class doesn't work, because with "tools" you are making special classes that Sketchup watches. So you have to tell sketchup to start your class as a tool.
                • B
                  BTM
                  Okay πŸ‘
                  Man, I've got a LOT to learn πŸ˜†
                  • B
                    BTM
                    ` require "sketchup.rb"
                    class Pinchmover
                    	def activate
                    	@model = Sketchup.active_model
                    	@ent = @model.entities
                    	@view = @model.active_view
                    	@slct = @model.selection
                    	@slct.clear
                    	def onLButtonUp(flags, x, y, view)
                    	ip = view.inputpoint x,y
                    	pt = ip.position
                    	pt2 = Geom::Point3d.new pt
                    	@cpoint = @ent.add_cpoint pt2
                    plugins_menu = UI.menu("Plugins")
                    item = plugins_menu.add_item("Pinch Mover") {
                    I like mouse interaction and inferencing better than a dumb little inputbox πŸ’š
                    ... Now to get it to make only ONE cont.point ...
                    ... And THEN a way to select an endpoint for the tool to use as the centerpoint of the pinch πŸ˜’
                    • B
                      BTM
                      ; But now I think I know how to tackle both issues at once 😎
                      • Chris FullmerC
                        Hey, that's great! Its adding the construction point really well. Once its added, you have its position so you know where the pinch is going to. The second cpoint should indicate the vertex to be used.
                        I agree, you have to figure out those things, so I'm interested to hear how you do it!
                        • Chris FullmerC
                          That works great! You have two separate points defined and stored for later use. Perfect. Now you have to decide how you want your script to move forward. Does it just begin automatically once the 2nd construction point is set? Or does it pop up a radius input box immediately after the 2nd point is added. Or does it just sit there until the user hits enter? Once they hit enter then it beings running. etc.
                          So far so good. You've gotten past much of the mouse implementation. Now its on to transformations! WooHoo!
                          • B
                            BTM
                            **` require "sketchup.rb"
                            class Pinchmover
                            	def activate
                            	@ip = Sketchup::InputPoint.new
                            	@slct.clear
                            	@first = 0
                            	@second = 0
                            		if @first == 0
                            		ip1 = view.inputpoint x,y
                            		pt1 = ip1.position
                            		pt2 = Geom::Point3d.new pt1
                            		@first = 1
                            		@second = 1
                            		elsif @second == 1
                            		ip2 = view.inputpoint x,y
                            		pt3 = ip2.position
                            		pt4 = Geom::Point3d.new pt3
                            		@cpoint2 = @ent.add_cpoint pt4
                            		@second = 2
                            	def onReturn(view) #Unnecessary, I just want to see if it's working.
                            	UI.messagebox @cpoint
                            	UI.messagebox @cpoint2
                            πŸ˜„
                            ... So?
                            • B
                              BTM
                              I edited that last post about 30 seconds ago, so that it would have different variables to repeat. I don't know if it'll help, but I thought it would be a good idea.
                              • ely862meE
                                ely862me
                                i don t know where to ask so i ll ask here...is there any chance to make a small code or plugin for deselecting a line or something else without zooming out and click away from model..
                                i was thinking to rewrite the esc key sketchup function (..if u are in a group or is selected a group by pressing esc the group is deselected or is closed )...i would like by hitting the esc key to deselect the selected geometry
                                Sorry for bad phrases πŸ˜„
                                Elisei
                                Elisei (sketchupper)
                                Come and See EliseiDesign
                                • Chris FullmerC
                                  You can go ahead and start a new thread generally for questions like that... πŸ˜„
                                  The answer is ctrl-t. Deselect is already built into SketchUp, and that is the default shortcut key. If it doesn't work, then you've probably mapped it to something else. Go re-map it to they key that you want.
                                  • B
                                    BTM
                                    Well, first of all, the plugin would be easy. Unfortunately though, you'd have to add a shortcut key to cet plugin, because, as far as I know, plugins seem to work only when they are in use. Unless it's somehow possible with initialize. πŸ˜•
                                    • ely862meE
                                      ely862me
                                      U re the MAN ..it works..
                                      I asked some time ago and the answer was zooming out and click away..
                                      Thanks for the tip..
                                      Btw you are doing a great job with all these plugins ..Thanks for that too!
                                      Elisei
                                      • B
                                        BTM
                                        ... For me, shift alt a.
                                        • B
                                          BTM
                                          Okay. Here's my big issue, I knew I'd end up having.
                                          this is the part I added to the end of the elsif in onLButtonUp:
                                          prompts = ["Radius="] defaults = [ 0.0.to_l] list = [""] results = UI.inputbox prompts, defaults, list, "Please input desired radius." @rad= results
                                          Now, HOW can I go through all the active points in the model**(to see which ones are within the distance of @rad from @cpoint2 in the future)**? I can't use .typename, because endpoints aren't really entities, so I'm stuck.
                                          • Chris FullmerC
                                            This is what I use to iterate through a model for vertices.
                                            ents = Sketchup.active_model.active_entities
                                            verts = []
                                            ents.each do |e|
                                             if e.typename == "Edge"
                                              verts << e.start
                                              verts << e.end
                                            verts.uniq!
                                            That adds every start vert and every end vert to the array, then .uniq! removes all duplicates.
                                            Now you have an array of all vertices in an array. This is the transformation method you will need to use in this script:
                                            Error 404 (Not Found)!!1
                                            (code.google.com)
                                            There's lots of ways to transform things, but most of them transform one object at a time, which won't work for what your doing (I don't think it will at least). So this transform is cool because it does it all at once. What you need to create is an array of vectors that correspond to your array of vertices. The vector should be the vector that your vertex will move. Hope that helps with the next step,
                                            • 2 / 3
