    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 205.4k Views 88 Watching
    • Chris FullmerC Offline
      Ahh, that picture is more clear.
      In the 2nd version I'm quickly adding and deleteing construction points, and the way I had implemented it crashed the plugin in the middle of making construction points if the segments did not match.
      I already had to fix it in the version I'm working on because I'm trying to make it work VERY smoothly with any number of segments. I have high(poly) hopes for the next version.
        coldsteel
        I really appreciate you 👍
          sepo
          Hmmm... I am having a problem. It worked no problem but now just stopped. It is giving me error
          Error: #<NoMethodError: undefined method start' for #<Sketchup::Face:0x72aa908>> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:234:in order_points'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in order_points'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in `onLButtonUp'
          Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61:in onLButtonUp'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61 Error: #<NoMethodError: undefined method all_connected' for nil:NilClass>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233 Error: #<NoMethodError: undefined method start' for #Sketchup::Face:0x72aa908>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:234:in order_points' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in each'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in order_points' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in onLButtonUp'
            sepo
            screen grab
              Sounds like you have a tiny face attached to one of those splines. Look closely. The script doesnt check for that - yet. Once I get out of beta testing I'll have that all included (and I'm still in alpha, so it might be a little while).
              • N Offline
                notareal
                Wow!
                  sepo
                  Spot on...Chris...it was minute face... 👍
                    jmmad
                    I can't see any little face in that picture.
                    But you can from the code ?
                    Can you read the matrix Chris? 😲
                    Get Upa !
                      The first line was what gave it away:
                      Error: #<NoMethodError: undefined method `start' for #Sketchup::Face:0x72aa908>
                      I could tell it found a face, and I'm very aware that my script will break upon finding faces (and images, text, groups, components, 3dpolylines, etc) , so it was a safe guess. 😆
                      • I Offline
                        ilay7k
                        Chris, thanks a'lot.
                        • MALAISEM Offline
                          MALAISE
                          I see now a lot of use on Geology and/or GIS displays.
                          A small thanks compared to your works 👍 👍
                          MALAISE
                          • H Offline
                            haynesc
                            Vista : 7 pro ...
                            sketchup crashes when using loft inside components
                              AcesHigh
                              it was so small it was more like a millisecond face 😆
                                @haynesc said:
                                Vista : 7 pro ...
                                ...as well as in groups. See here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=157130#p157130 - hopefully it will be easy to fix.
                                  Sorry about the group crashing thing. TIG has helped explain that to me and it should fixed in the next release (which will hopefully be soon!, but no promises).
                                    sepo
                                    lol You 2 have same avatars.
                                      Just invert one horizontally 💚
                                        What? I hadn't noticed. That thief!
                                        • ely862meE Offline
                                          ely862me
                                          😄 look at him...who is talking 😠 .. 😛 😆
                                          Elisei (sketchupper)
                                          Come and See EliseiDesign
                                            Whaaaaaat? Its like a plague!
                                            (actually I changed mine after I saw that Coen had changed his and you had changed yours, so yeah, I'm the thief. I'm hoping that at some point it will annoy Gaieus so much that he'll change his back to some random animal again and we can all go back to our old selves).
                                            • 12
                                            • 13
                                            • 5 / 13
