    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 216.4k Views 88 Watching
      sepo
      No it is not bug. Plugin tells you that you do not have same number of segments. The top one has more segments than the arc.
      • C
        coldsteel
        but now something change
        because I replace the ‘Simple Loft alpha 0.1b version ’ by 'the early version'
        why
        • X
          xrok1
          nice one 😉
          • Chris FullmerC
            @TIG - Really??? That's cool. I need to explore that. I don't feel like I understand entities. vs. active_entities very well yet. I might have another version ready for release today and I'll include that in it. Thanks!
            @Coldsteel - Sepo was right, that is the plugin crashing because you didn't have the same amount of segments on the top and bottom splines. When you reverted to the older version, your splines all have the same amount of segments so it is working. But the new version will work also with those same splines.
            Great feedback everyone! Thanks so much.
            • C
              coldsteel
              obviously two lines have different number of segments
              but it can work under the earlier version
              that's funy 🎉
              • C
                coldsteel
                So that explains it
                哈哈
                • Chris FullmerC
                  Ahh, that picture is more clear.
                  In the 2nd version I'm quickly adding and deleteing construction points, and the way I had implemented it crashed the plugin in the middle of making construction points if the segments did not match.
                  I already had to fix it in the version I'm working on because I'm trying to make it work VERY smoothly with any number of segments. I have high(poly) hopes for the next version.
                  • C
                    coldsteel
                    I really appreciate you 👍
                      sepo
                      Hmmm... I am having a problem. It worked no problem but now just stopped. It is giving me error
                      Error: #<NoMethodError: undefined method start' for #<Sketchup::Face:0x72aa908>> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:234:in order_points'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in each' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in order_points'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in `onLButtonUp'
                      Error: #<NoMethodError: undefined method all_connected' for nil:NilClass> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61:in onLButtonUp'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61 Error: #<NoMethodError: undefined method all_connected' for nil:NilClass>
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:61:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233 Error: #<NoMethodError: undefined method start' for #Sketchup::Face:0x72aa908>
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:234:in order_points' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in each'
                      C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:233:in order_points' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_simple_loft/clf_simple_loft.rb:65:in onLButtonUp'
                        sepo
                        screen grab
                        • Chris FullmerC
                          Sounds like you have a tiny face attached to one of those splines. Look closely. The script doesnt check for that - yet. Once I get out of beta testing I'll have that all included (and I'm still in alpha, so it might be a little while).
                          • N
                            notareal
                            Wow!
                              sepo
                              Spot on...Chris...it was minute face... 👍
                                jmmad
                                I can't see any little face in that picture.
                                But you can from the code ?
                                Can you read the matrix Chris? 😲
                                Get Upa !
                                • Chris FullmerC
                                  The first line was what gave it away:
                                  Error: #<NoMethodError: undefined method `start' for #Sketchup::Face:0x72aa908>
                                  I could tell it found a face, and I'm very aware that my script will break upon finding faces (and images, text, groups, components, 3dpolylines, etc) , so it was a safe guess. 😆
                                  • I
                                    ilay7k
                                    Chris, thanks a'lot.
                                    • MALAISEM
                                      MALAISE
                                      I see now a lot of use on Geology and/or GIS displays.
                                      A small thanks compared to your works 👍 👍
                                      MALAISE
                                      • H
                                        haynesc
                                        Vista : 7 pro ...
                                        sketchup crashes when using loft inside components
                                          AcesHigh
                                          it was so small it was more like a millisecond face 😆
                                          • GaieusG
                                            @haynesc said:
                                            Vista : 7 pro ...
                                            ...as well as in groups. See here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=157130#p157130 - hopefully it will be easy to fix.
                                            • 12
                                            • 13
                                            • 5 / 13
