    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 155.8k Views 88 Watching
      sepo
      Interesting...it works no problem on SU6 with 2 or more arcs.
        sepo
        If you are refering to my case ....they had only same number of segments but not same curves.
        • Chris FullmerC Offline
          Bummer Sepo, your getting splats on any loft in v7?
          Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
          So perhaps attach some example models and I'll take a look. Thanks!
          EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
            @dtrarch - Lofting 3 equal arcs in SUv6 gives bug splats? But 2 equal arcs do not, correct? Could you post a model that splats?
            I'll look into it and I have a pretty good idea where in the code to start looking. I can't think of anything I've done that should splat though. Oh well, I'll try to check it out.
            • W Offline
              watkins
              Dear Chris,
              I cannot seem to get your plugin to work. The loft icon appears in my toolbar, and seems to work: it changes when selected and allows the selection of the two curves (simple arcs with the same number of segments), but then nothing. I even tried exploding the arcs, but still nothing.
              As usual, I put the simple_loft folder and loader in my plugin folder. Is it possible that one of my other plugins is causing a problem? I have tried your plugin on two different computers (home laptop and office desktop), but with the same result. Both have the same plugins. Curious.
              Kind regards,
              Bob
                sepo
                This is console . I start loft and have this
                --> New Definition Added:
                --> 0
                --> nil
                I select arcs,press ok in GUI have this for 1 second
                --> 0
                --> nil
                and than bugsplat....now this happens in SU7 even with simple curves.
                • W Offline
                  watkins
                  Dear Chris,
                  I do apolgise. I had a senior moment, or to be more precise, I failed to read your instructions to the end. Hit ENTER was the missing step. Seems to work just fine now.
                  Kind regards,
                  Bob
                    Click Draw
                    Hey Chris,
                    Been playin' a bit...so far no probs. I'm on SU7 Pro, Vista if that helps.
                    Jeff
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                      dtrarch
                      I checked V6 with only loft installed.
                      It is bumping into another script or ?
                      The same script set is on V7 and loft is OK there.??
                      BTW the number of arcs 2-whatever still bombed.
                      Dave
                      • W Offline
                        watkins
                        Made using simple_loft
                          kwistenbiebel
                          Hi Chris,
                          You and Fredo can have the Nobel Prize, whatever the category.
                          Marvelous in all ways !!! 👍
                          Google, eat your heart out (again)!
                            sepo
                            Quite bizzare. On Vista comp SU7 works fine but not on XP SU7, However on same XP SU6 it works. I will now try on my XP laptop.
                              Sepo, your issue to me looks very much like an observers problem - specifically a collision with another script that is watching the selection set being added to. I'm sorry for the hassle, but you might need to remove plugins a few at a time until you find the culprit.
                              @Bob, glad you found the problem. That was going to be my suggesion, but I'm glad you got it working! The bowl looks great. I'm guessing you made it using half circles and then combined them together? Very nice!
                              @Dave, weird that it is splatting on version 6. You tried it with nothing else installed? Are you on Vista? Is there a chance you have any hidden plugins in the compatibility folders? That has ruined my scripts for more than one person already....grrr. Could you open the Ruby console (Window>Ruby Console) and see if you are getting any notices in there when running the script?
                              @Jeff, thanks! Glad to hear its working good for someone.
                              I really don't know whats causing some of these splats. We'll keep trying to troubleshoot it.
                              Thanks for the feedback,
                                Heehe, Thom is really digging deep into observers in that script. I'll PM him and let him know that he's got a leak. Thanks for taking the time to find it Sepo!
                                  sepo
                                  OK good news is it works on my laptop on both SU7 and SU6.
                                  On my other XP I found culprit. It is tt_double_cut.rb.... As soon as I removed it(as this was only one which was not on all comps) loft started to work.
                                  I know Tom's script is only alpha but it seems to clash with yours.
                                    sepo
                                    Is it possible to make circles or elipses to be lofted?
                                      Not yet. I started with open splines only. I have to rethink some pieces of the script to get closed splines to work.
                                        sepo
                                        Sounds promissing....Thanks for the script...It looks like there is a less and less reason to leave SU...
                                          AcesHigh
                                          so far, it seems the best option is to create two halfs of the closed loop you want (be it a circle, elipse or anything else). Than you loft and join them.
                                          If you want to loft a circle to a line, MAYBE its possible to cut the circle in two. Then you loft half the circle to the line, and then you loft the other half of the circle to the same line. Then you join the two sides.
                                            jmmad
                                            Well i was thinking about leaving SU and one of those reasons where no loft support.
                                            Until now.
                                            You are really making Great Plugins you are very generous an talented man.
                                            Thxs a lot Chris.
                                            Get Upa !
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
