    Please can someone check this plugin.NEW VERSION
    12 Posts 6 Posters 1.0k Views 6 Watching
      DIEGO-RODRIGUEZ
      It seems very interesting. But I can not get work
      http://akitenh.dip.jp/blog/pic/suji.png
      http://akitenh.dip.jp/blog/2009/05/post_114.html
      suji.rb
      suji-1.rb
        Bug Splat for me in V6 and v7 (maybe because some japan characters are inside ?
          DIEGO-RODRIGUEZ
          someone can correct?
            Jim
            The script itself looks Ok to me (looking at the source code) - the crash it is likely the odd character set used in the stings. Can yiou guess at the translations?
            What is the purpose of the "cage?"
              DIEGO-RODRIGUEZ
              view tutorial
              http://akitenh.dip.jp/blog/pic/suji.htm
                Jim
                I managed to capture the Ruby Console on crash - I have never seen anything like it.
                  Jim
                  It only works on the vertical, by design. The second number (45) in the prompt is the thickness of the "slat". I'm not sure what the first (default 90) is.
                    Roger
                    My guess as this is from Japan, it is a quick method of adding earthquake bracing to framing. What do you think?
                    http://www.azcreative.com
                      DIEGO-RODRIGUEZ
                      Thanks Jim. How did you work?
                      I use windows xp and sketchup7. Someone can fix it to go?
                      Sorry for my English. is quite basic
                        RickW
                        Just a guess (no time to try it), but 90 & 45 could be the framing member size (90mm is about 3.5 inches, 45mm is about 1.75 inches, or a "metric 2x4"). I have a friend looking into it. I agree that it's probably the character set causing the problems.
                        RickW
                        www.smustard.com
                          DIEGO-RODRIGUEZ
                            Sujikai refers to something that's diagonal, oblique or bracing - e.g. in patterns - like on sword hilts - or perhaps in stud-wall bracing, as it appears here... Exactly what is this script trying to do ? If we knew that, then we could edit out the rogue 'Japanese characters' and see how it might work as hoped...
