Planted Roof (Sedum) Texture
Does anyone know where I could get hold of a map for a planted roof?
I have tried applying a grass texture but really need something with some variety to make the roof more realistic or at least contrast with the grass adjacent.
Manythanks
Andrew
If you go here: http://www.cgtextures.com/ then go nature->grass theres quite a few good textures. If you want something really good id suggest getting a few textures from there then combining them in photoshop.
Andrew are you planning to render or straight SU ouput?
Remus - that's a superb site. The 'groundplants' are great. It would be better to spend some time with Photoshop but I have not created a repeating texture before.
Solo - I'll be outputting from SU. I have a friend who uses Max but SU should be fine for my purposes.
Andrew
Might interest you to see one company that is leading in that field.
(you may not be able to read the language, however if you hover your mouse pointer over the menu, you can see the menu in English at the bottom of the page)
Andrew, if you want to photoshop-up your SU image a bit, I do a simple process for making your roof look grassy, unfortunately I can't paste the results here as my only example is a commercial image but if you are interested let me know and I'll post a quick tut.
I would certainly be interested in a tutorial. I'm working on a project with greenroofs as well.
