    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 652.2k Views 667 Watching
      Zdravo Kristijan,
      (and in English, as my Croatian is a bit rusty), welcome to SCF! I actually know there's a similarly young person who is a member here from Croatia (Dubrovnik).
      Looking forward to seeing your models!
        Croatia SketchUp
        And ho is that young boy from Dubrovnik?
        I'l send som pictures of my works, so you can se how I work.
        Do you now what will happend if you fall?
        You will fall!
          He's Robert Soletić. Hasn't ben active for a while though. What exactly do you model?
            Croatia SketchUp
            Look at gallery-my gallery, I work everything
            You will fall!
            • V Offline
              vashstamp3de
              Hi!
              Im John, but everyone calls me vash. Since the first time ive heard about sketchup from a friend, ive been curious on how flexible and easy it is to use.
              Im an interior designer, and part of my duties are making models of interiors which is hard to do especially from other 3d software.
              But as a start, here is one minor problem i wish to get removed.
              http://img13.imageshack.us/img13/8198/edges.jpg
              As you can see, its hard for me to work with this dark edges showing, although ive tried everything under View *menu bar(tuned off and on almost all command there), nothings seems to remove them.
              If possible, I wish to see clean corners and joints. Need help, thank you!
                remus
                Hello vash πŸ‘
                To get rid of those endpoints, go window->styles->edit then deselect endpoints. Its worth deselecting profiles while your at it, as they slow performance slightly and dont look particularly nice.
                • Y Offline
                  yf90
                  Hi im new here
                  i would like to learn podium
                  mind anybody give me a tutorial pdf about it
                  thx btw!
                  • V Offline
                    vashstamp3de
                    Problem solve! Thank you, you're a great help!
                    @remus said:
                    Hello vash πŸ‘
                      Croatia SketchUp
                      Hello yf90
                      Here's you'r help.
                      I think that, that is what you need.
                      You will fall!
                        afaque
                        Hi My self afaque,
                        Could any one of you please tell me from where i can download @free scale . it feels to me its agreat plugin as i have gone through the videos
                          Hi Afaque and welcome.
                          Here is the plugin (attached at the bottom of the first post):
                          http://www.sketchucation.com/forums/scf/viewtopic.php?p=144180#p144180
                          Note that in order to use it, you'll also need to install this plugin:
                          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178
                          Both have folders and rb files inside; everything should go unchanged (i.e. keeping folder structure and all) directly under the Plugins folder.
                          • Y Offline
                            yf90
                            Thx for all the help!
                            im using artlantis currently
                            is artlantis good?or podium?
                            looking for a good renderer here
                              ml77
                              I am a new member must know the load Vismat Material for Vray. πŸ’š πŸ’š
                              • W Offline
                                waredatamredpcdr
                                Hello I have just downloaded this program, When i open it up I have a blank page, cannot see any lines or markings? What I'm I missing??
                                  SuManSharma
                                  Hi All!! This is SuMan from India..
                                  Gud to be a member of this forum and looking forward to enhance my sketchup skills through your help πŸ‘ ...
                                  I use SU7 and want to know if there is any way to open the SU7 file in SU6 which can be edited in SU6..
                                  ThnQ,
                                    remus
                                    Welcome SUman,
                                    If you go file->save as then change the format to SU 6 you will then be able to open your SU7 files in SU6.
                                      Hello Nora and welcome.
                                      Can't you see anything when drawing (say) a line either?
                                      Could you try this test: Go to Window > Preferences > OpenGL and uncheck "Hardware acceleration". If this "seems" to help, try to update your video driver rather than leaving it like this (because without HW acceleration SU can be slower).
                                      What video card do you have by the way?
                                        SuManSharma
                                        @remus said:
                                        Welcome SUman,
                                        ThnXX for the reply but the file is opening as a read only file in SU6 when saved in this manner..
                                          remus
                                          Did you close SU7 before opening it in SU6? windows doesnt like you having the same (write enabled) file open in 2 different programs.
                                            Hi Jack and welcome to the forums.
                                            Indeed Dave can make SU look a fantastic tool (which it is actually) so I'm not surprised. To make sure you get the "most" out of SCF, I registered you at the Woodworking forum (which is subscription based and I saw you were not a member of it yet).
                                            • 66
                                            • 67
                                            • 68
                                            • 69
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 68 / 73
