    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.5m Views 667 Watching
    • Y
      yf90
      Hi im new here
      i would like to learn podium
      mind anybody give me a tutorial pdf about it
      thx btw!
      • V
        vashstamp3de
        Problem solve! Thank you, you're a great help!
        @remus said:
        Hello vash πŸ‘
        To get rid of those endpoints, go window->styles->edit then deselect endpoints. Its worth deselecting profiles while your at it, as they slow performance slightly and dont look particularly nice.
        • C
          Croatia SketchUp
          Hello yf90
          Here's you'r help.
          I think that, that is what you need.
          Do you now what will happend if you fall?
          You will fall!
            afaque
            Hi My self afaque,
            Could any one of you please tell me from where i can download @free scale . it feels to me its agreat plugin as i have gone through the videos
            • GaieusG
              Hi Afaque and welcome.
              Here is the plugin (attached at the bottom of the first post):
              http://www.sketchucation.com/forums/scf/viewtopic.php?p=144180#p144180
              Note that in order to use it, you'll also need to install this plugin:
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947#p144178
              Both have folders and rb files inside; everything should go unchanged (i.e. keeping folder structure and all) directly under the Plugins folder.
              • Y
                yf90
                Thx for all the help!
                im using artlantis currently
                is artlantis good?or podium?
                looking for a good renderer here
                  ml77
                  I am a new member must know the load Vismat Material for Vray. πŸ’š πŸ’š
                  • W
                    waredatamredpcdr
                    Hello I have just downloaded this program, When i open it up I have a blank page, cannot see any lines or markings? What I'm I missing??
                      SuManSharma
                      Hi All!! This is SuMan from India..
                      Gud to be a member of this forum and looking forward to enhance my sketchup skills through your help πŸ‘ ...
                      I use SU7 and want to know if there is any way to open the SU7 file in SU6 which can be edited in SU6..
                      ThnQ,
                        remus
                        Welcome SUman,
                        If you go file->save as then change the format to SU 6 you will then be able to open your SU7 files in SU6.
                        • GaieusG
                          Hello Nora and welcome.
                          Can't you see anything when drawing (say) a line either?
                          Could you try this test: Go to Window > Preferences > OpenGL and uncheck "Hardware acceleration". If this "seems" to help, try to update your video driver rather than leaving it like this (because without HW acceleration SU can be slower).
                          What video card do you have by the way?
                            SuManSharma
                            @remus said:
                            Welcome SUman,
                            ThnXX for the reply but the file is opening as a read only file in SU6 when saved in this manner..
                              remus
                              Did you close SU7 before opening it in SU6? windows doesnt like you having the same (write enabled) file open in 2 different programs.
                              • GaieusG
                                Hi Jack and welcome to the forums.
                                Indeed Dave can make SU look a fantastic tool (which it is actually) so I'm not surprised. To make sure you get the "most" out of SCF, I registered you at the Woodworking forum (which is subscription based and I saw you were not a member of it yet).
                                • B
                                  bluecollar
                                  I have been using sketchup for a few years now as a furniture designer/manufacturer,and am keen to find information on using SU models for CNC routing.
                                  SU is by far and away the best 3d design platform for furniture πŸ˜„
                                  • B
                                    bluecollar
                                    P.S any chance I can get on the woodworkers forum too? I am having trouble finding the login page
                                      remus
                                      Evening(or morning/afternnon depending on where you are) bluecollar,
                                      you can get to the woodworkers forum by going to the user control panel (top left of the forum) then going to usergroups and signing up from there.
                                      • B
                                        bluecollar
                                        Thanks Remus late evening here in South Africa
                                          alarm
                                          HI ALL my name Alam from Kuala Lumpur,Malaysia. Reactive forum back, before this i just the watcher and reader only!
                                          Website at alamdesign.com
                                          Blog http://www.sketch-stuff.blogspot.com
                                          • GaieusG
                                            Hi Alam and welcome to SCF!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 72
                                            • 73
                                            • 21 / 73
