    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.5m Views 667 Watching
    • Chris FullmerC
      I'd say start new threads. This one is designated to say hi to new users. Some people don't read this, but if you pst a new thread, with a good title that explains what your problem is, your much more likely to get more eyeballs on your post. Thats my thoughts,
        Seydell
        Thanks Chris. I'll do just that. On a general note, is there any further registration or subscription requirement for the special interest groups within the SUF?
        • Chris FullmerC
          There are some forums that you have to register to see them. Go the your user control panel, and UserGroups tab to see all the other subforums:
          404 Not Found
          (www.sketchucation.com)
          Hope that helps,
          • GaieusG
            A bit more note on that: you can register to the "public" UG's that are subscription based. Obviously you cannot register into the Google SketchUp Team UG (they are the Google employees) or to the moderators group just like that. There are sometimes other groups, too, like the challenge winner UG but obviously you need to deserve to be the member (I am not a member either so it's not just like that, again).
            • N
              nerble
              Howdy all, Im new to this forum ,but not exactly new to scetchupin,I model production drawings from blueprints for a small Timber Frame shop in eastern TN. I have su7 on my xp machine at home ,but can not seem to get it for my 2000 machine at work..... i have su6 on it but would to get su7 as that is what our newer vista machine runs...... kinda hoping there is some patch or somthing that would save me buying a whole new system.......any help?
              • DoodlerD
                Doodler
                Hi Everyone, I'm new to this forum, only been using SketchUp7 for less than 3 weeks. I upgraded to a gaming laptop running Vista64 and my Autocad would not run on it. I decided to find a program that would run on Vista64 without problems. I needed to design a custom tool storage and shelving system for my shed. First I installed SketchUp7 and then bought a book named Google SketchUp 7 for Dummies, and within a week and a half I had my design finished. I used CATIA and Autocad at work, so I had an idea about 3D programs. I must say I really like how easy it is to learn how to use SketchUp. The tutorials on this site and other sites helped speed up the initial learning curve to a flat track at the dragstrip. My next project is to build another shed to my county specs for my motorcycle, riding mower and an area for repairing or storage. The shed can't be over 200 sq ft, to avoid getting a permit and increase in my property tax. I'm sure I'll have some questions and hopefully have some good tips to help someone else. β˜€
                • GaieusG
                  Hi Joe and welcome.
                  Let's see those questions. πŸ˜‰
                  BTW if you cant build a shed over 200 sq feet, why don't you build two of them? πŸ˜„
                  • DoodlerD
                    Doodler
                    Hi Gaieus, Thanks for the welcome. This is a great forum for SketchUp. I am actually designing a third shed. You would think that the best thing to do is build a large garage, but in my county homes are only reassessed for taxes when they are sold or when permits are issued. My last assessment was in 1989 and my home has tripled in value. You can see why I am resisting getting a permit. I did have a question, but after reading a comment on the forum yesterday and experimenting today, I believe I have the answer to my problem. My problem was when I drew a wall stud 2" x 4" x 67" and made it into a component on layer 0, I would make multiple copies of that component on the same layer, to use in other layers. When I would use that stud component on layer 2, it would disappear when I unchecked the Visible box for layer 0. I tried using make unique, but that did not solve my problem. I think I have to open the entity info dialog box and change the layer of the copied component. β˜€
                    • GaieusG
                      That's probably the solution. You cannot just "copy" things from one layer to another but you have to change their layers in (for instance) the entity dialog.
                      The same component definition can have different instances on different layers so you need not make them unique for that. In fact, you only need to make any component unique if you want to make any changes that can only be done "inside" their editing context - and assigning them onto layers is not such an operation.
                      • DoodlerD
                        Doodler
                        Thanks Gaieus, Your suggestion works great. I have tried it several times and it completely solves my problem of having different instances of components on different layers disappearing. β˜€
                        • W
                          wheezy
                          Hello Sketchers!
                          Just started using Sketchup 7 to create models of an invention I've dreamed up. I needed an easy way to create drawings for injection model makers to understand what I'm trying to achieve. It's been a huge time saver and perfect for designing prototypes. I've been amazed at what I can create with my limited knowledge. Really easy to get started.
                          Before I was creating models out of clay. And since I have no artistic ability that was a serious waste of clay. 😳 Now I can work out a design and make a prototype on a wood lathe.
                          I've been going through the "DUH!" thread and find some great tips. Well off to the woodshop.
                          • GaieusG
                            Hi Wheezy and welcome!
                            From the "DUH" thread, you can see that SU has its depths and even experienced users can learn something every day. Yet you are right; SU is great because even beginners can easily achieve success and thus be encouraged to go further.
                            • C
                              Croatia SketchUp
                              Hello
                              My name is Kristijan, I'm 11, and I am from Croatia, I was started to work about 1 year ago, hope I will enjoy here.
                              Sorry for my English.
                              Do you now what will happend if you fall?
                              You will fall!
                              • GaieusG
                                Zdravo Kristijan,
                                (and in English, as my Croatian is a bit rusty), welcome to SCF! I actually know there's a similarly young person who is a member here from Croatia (Dubrovnik).
                                Looking forward to seeing your models!
                                • C
                                  Croatia SketchUp
                                  And ho is that young boy from Dubrovnik?
                                  I'l send som pictures of my works, so you can se how I work.
                                  You will fall!
                                  • GaieusG
                                    He's Robert Soletić. Hasn't ben active for a while though. What exactly do you model?
                                    • C
                                      Croatia SketchUp
                                      Look at gallery-my gallery, I work everything
                                      You will fall!
                                      • V
                                        vashstamp3de
                                        Hi!
                                        Im John, but everyone calls me vash. Since the first time ive heard about sketchup from a friend, ive been curious on how flexible and easy it is to use.
                                        Im an interior designer, and part of my duties are making models of interiors which is hard to do especially from other 3d software.
                                        But as a start, here is one minor problem i wish to get removed.
                                        http://img13.imageshack.us/img13/8198/edges.jpg
                                        As you can see, its hard for me to work with this dark edges showing, although ive tried everything under View *menu bar(tuned off and on almost all command there), nothings seems to remove them.
                                        If possible, I wish to see clean corners and joints. Need help, thank you!
                                          remus
                                          Hello vash πŸ‘
                                          To get rid of those endpoints, go window->styles->edit then deselect endpoints. Its worth deselecting profiles while your at it, as they slow performance slightly and dont look particularly nice.
                                          • Y
                                            yf90
                                            Hi im new here
                                            i would like to learn podium
                                            mind anybody give me a tutorial pdf about it
                                            thx btw!
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 72
                                            • 73
                                            • 20 / 73
