    SU5 license error
    14 Posts 6 Posters 1.1k Views 6 Watching
    • T
      tomsdesk
      Well, I did a bunch of differently worded google searches and finally came up with an SU6 answer that worked on SU5, thank god: "right click the desktop icon, click 'run as adminstrator', then fill out the authorization info"...vista is gonna drive me mad isn't?!?
      2.5D Trees & Shrubs!
        remus
        Once youve got everything installed it isnt too bad πŸ˜‰
        • GaieusG
          Oh, sorry, Tom, the "administrator" thing with Vista and SU was kind of obvious to me (and definitely not SU 5 speific) that I didn't even think about it first. Sometimes you even need to run SU first like this in order to get Vista to believe it is legitimate.
          But at least you have it correct now. πŸ‘
          • AndrewSA
            AndrewS
            <Shameless plug>
            In the latest version of SU7, this problem is corrected by some trickery we perform at install time.
            </Shameless Plug>
            Andrew S.
            SketchUp Release Engineer
            • Chris FullmerC
              Hey, could you employ that same trickery to over-ride any authorization needed so I can install it on my school computers when I have no admin priveleges at all? πŸ˜„
              • AndrewSA
                AndrewS
                πŸ˜„ I like your thinking, but unfortunately, no. The trickery is to require the user to authenticate at install time, which allows us to perform future licensing operations without requiring the user to choose "run as administrator".
                Andrew S.
                • Chris FullmerC
                  Ahh well, wishful thinking πŸ˜„ Thanks for the update on that Andrew. Its always good to know a little bit more about how SU is working, especially since we do quite a bit of installation troubleshooting.
                  Though, not nearly so much since the new version doesn't require the discussed administrator workaround anymore. Thanks!
                  • GaieusG
                    Thanks for that, Andrew. I haven't come to the happy hance to run SU on Vista yet. Hopefully when XP runs out eventually, Windows 7 (or even later) will replace Vista and be already bugfixed with a couple of service packs. πŸ˜„
                    (Just don't tell me that SU 8 won't support XP as SU 7 doesn't support Win 2000 any longer πŸ˜‰ )
                    • AnssiA
                      Anssi
                      SU 8? There's going to be a SU 8? πŸ˜„
                      Anssi
                      • GaieusG
                        Sure! With high poly (billions of polys with easy orbiting), multi core, 64 bit, proxy, animation and hdri support and a fix for the shadow bug (actually, a WYSIWYG, real time PR renderer will also be added)
                        πŸ˜’
                        They are now writing the exporters for Max, Cinema4D - even Vue - and all because they will be toys compared to SU.
