    Group components from array
    13 Posts 4 Posters 691 Views 4 Watching
    • H Offline
      HPW
      When I import a Autocad DWG my blocks get components in SU.
      The outliner show them in his list.
      Now I want to group some components together.
      (like manual selecting them and choose 'Make Group')
      I get it so far that I have an array of all wanted groups
      and an array for each group with the wanted components.
      With this code I create the empty groups:
      grouplist.each{|c|
         group = entities.add_group
         group.name = '<'+c.rjust(5)+'>'
      The empty groups show up in the outliner at the expected positions.
      But how do I add the existing components from array to their groups?
        Use the array of entities as argument for .add_group.
        http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/entities.html#add_group
        • H Offline
          HPW
          But waht about the quote in the doc:
          NOTE: calling add_group with entities in its parameters has been known to crash SketchUp. It is preferable to create an empty group and then add things to its Entities collection.
          • H Offline
            HPW
            Anyway I give it a try and it works nicely.
              grouplist.each{|c|
               str = '@my_group_list = GroupPrefix'+ c
               eval str
               group = entities.add_group(@my_group_list)
               group.name = '<['+c.rjust(5)+'>'
            By the way: Is there a better way to create dynamicly array names and recall them?
            The Grouplist is an array of strings like [ "100" "200" ...]
            The Group-arrays are like 'GroupPrefix100' etc.
              Jim
              Ruby is kind of cool in that you can increment Strings.
              name = "Group100"
              name.next #(also .next! and .succ & .succ!)
              ==> "Group101"
              Maybe useful?
                Yea, I've asked about that myself, but I've yet to hear about any concrete examples where it fails. And I don't know how you would move existing geometry into a group without rebuilding it from scratch.
                • TIGT Online
                  group=Sketchup.active_model.active_entities.add_group()
                  ### now we must assume you have an array of instances...
                  instances.each{|instance|
                    group.entities.add_instance(instance.definition,instance.transformation)
                    instance.erase!
                    ### remove the original instance - it's now been repeated in the group...
                  I think this is what you want ?
                  • H Offline
                    HPW
                    Thanks TIG, works also nicely.
                    But what is now the better or safer solution?
                    Hans-Peter
                    • TIGT Online
                      Why, mine of course ! πŸ˜‰
                      • H Offline
                        HPW
                        Very convincing reason!
                        πŸ˜‰
                        But is the warning in the doc correct of from an older version of SU.
                        Both shows me an identical result.
                        The first version is one code-line shorter.
                        • H Offline
                          HPW
                          Another observation: The first solution seems much faster.
                          When I leave the outliner open and run the code, the outliner flickers as long the code run.
                          But the first is much faster than the second one.
                          • TIGT Online
                            Having the Outliner open during script execution is risky as it can cause crashes when groups/instances are getting changed...
                            Adding stuff to groups immediately as they are made, in scripts can cause crashes, although I often do it - safest not to... Do whatever works for you best...
                            • H Offline
                              HPW
                              Thanks Jim for the tip.
                              In this case I can not use it, since my block-numbering-steps comes from the imported autocad-blocknames.
                              But maybe it gets usefull in the future.
                              Thanks again TIG.
                              Hans-Peter
