    Quick select edges using the eraser tool!
    14 Posts 7 Posters 12.4k Views 7 Watching
    • GaieusG
      @justry said:
      I posted this before, but looks like it got lost because of that server backup restore problem thing...
      Yes, sorry about that.
      And yes; a big welcome with such a nifty tip! 👍
        justry
        Thanks a lot guys, and the forum is really great, I love it!
          justry
          Go ahead man, it's all yours!
            StarWarsKnower
            Hey, great trick!
            Nobody made a big welcome like this when I started. 😢 😞 😢 😢 😠 😢 😢
            Just Kiddin.
            Mike
              justry
              Update: instead of all the right click thingy, you can just press any shortcut key (e.g. space for the select tool) before releasing the LMB. That'll still keep your edges selected.
              I saw this in a thread somewhere in the forums, but by the time I thought I'd add it here, I'd forgotten where I saw it, so if you know who it was please post his name here ☀ .
              • simon le bonS
                simon le bon
                Very useful. Thanks Justry
                  shopdude
                  That IS a great trick, learning learning...
                  There is so much in this forum, now I'll spend all my time w/ SU and never actually build anything!
                  Thank you, Shopdude
                  • simon le bonS
                    simon le bon
                    As I was trying to explain this so usefull tip to a friend, I decided to produce out a small screencast of it. Here is the result:(Remind: press spacebar before release EraserTool and that's it!)
                    [flash=475,436:x99jiuz8]http://www.viddler.com/simple/204a6c16/[/flash:x99jiuz8]
                    😉 simon
                      August
                      Thanks to all contributors for this.
                      Using the Spacebar makes it even easier and a bit intuitive. The Eraser first selects but does not actually erase until you release the mouse button. Think of pressing the Spacebar as changing the Erase selection to a Selection selection. "Opps, I didn't mean to erase, I meant to select; I'll just change tools in mid-action."
                      You can, of course, make the reverse change, in a way. "Opps, I didn't mean to select, I meant to erase." Just hit Delete.
                      But to collect the selection in the first place, dragging the Eraser tool is a LOT faster than Shift-Click, Shift-Click, Shift-Click, Shift-Click.
                      The Eraser is the only tool that I can think of that collects a selection before it actually operates. Anybody got any others?
                      I hope this adds something to the discussion,
                      August
                      “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                      [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                      • GaieusG
                        No,although there are other tools that autoselect (like the PushPull or Move or Rotate), they can only select one entity at a time.
                        On another note, the Eraser can only select edges (not faces) so the autoselect function of say the PP tool can be used for other tricks like reversing faces quickly - you only need to set up a shortcut key for the function itself and "browse through" the faces with the PP tool while hitting the shortcut like a madman.
                        Every tool has its own, little "side effect" 😄
                        • simon le bonS
                          simon le bon
                          excellent 👍 👍 . Works also of course with "del"
                          😉s
                          • simon le bonS
                            simon le bon
                            Dear all,
                            It seems fredo has developed the perfect tool which makes the tip of the Eraser Tool unnecessary:
                            [Plugin] HoverSelect 1.1d - Multi-selection of Edges
                            SketchUp is in the way to become a Fredoogle product 😆
                            *s
