    Lineweights and linestyles in Sketchup... finally possible!
    5 Posts 4 Posters 22.7k Views 4 Watching
      Gjenio
      It's incredible how some times long time problems can be solved in a easy and unthinkable way!
      So...
      In Google sketchup Pro 7 we have three wonderful apps:
      • Sketchup 7
      • Layout 2
      • Stylebuilder
      Why can't we make them working toghether just to solve our problems?
      That's the case of lineweights and linestyles apparently impossible to bring to sketchup!
      Not true
      Here is why:
      1)Make your model in Sketchup
      2)Create as many layers as different linestyles you need in your model
      3)Assign such layers to the entities of the model
      4)Create as many scenes as the number of linestyles
      5)In each of these Scenes turn to visible only the layer that correspond to the desired linestyle. Apply to that scene the corresponding *.style you have previously created with Stylebuilder.
      6)Repeat the step with all the linestyles you have in your model
      7)Go to Layout and create all the viewports that correspond to the scenes in your model.
      8)Lay the viewports one upon the other
      ...and that's all!
      I attached a little sequence of images to explain better the steps to do
      The working scene. Here you select entities and apply your desired layer that correspond to a precise strokestyle (lineweight and linestyle, previously created with Style Builder)
      Red pen only. Here is set to visible only the red pen layer, and has been applied the Red pen.style
      Dashed line only. Here is set to visible only the Dashed line layer, and has been applied the Dashed line.style
      Here we are in Layout! I've just created 2 viewports and placed one over the other. Now i just rigth click on the viewport above and choose Red pen under Scenes...
      ...then I select the viewport under, and set Dashed line as Scene type
      • U Offline
        urs0815
        good idea πŸ‘
        good tutorial πŸ‘
          August
          Hi Gjenio,
          That is very "inGjenious". (Sorry. People play games with my name too; I just could not resist.)
          I think the idea can be used by Free users too, simply by using a different program like Word, OO-Write, or MS-Paint to overlap the images.
          To be sure, I need a Free user to check something for me. (I have not figured out how to have both Free and Pro on the same machine for this kind of testing; I think it's not possible.)
          Would a Free user please go to Window > Styles > Select, click the + in the upper right to expand the window, and in the lower scroll bar, verify for me that the choices are the same as in Pro?:
          In Model
          Styles
          Assorted Styles
          Color Sets
          Default Styles
          Sketchy Edges
          Straight Lines
          Style Builder Competition Winners
          Also, would you please check that the Straight Lines set in the above list contains:
          Straight Lines 01px ... Straight Lines 10px
          If those Straight Lines Styles are in Free, then they should be all that is needed to follow Gjenio's method, at least for line weights. Dotted and Dashed lines are still a different issue.
          That caveat raises a question that I have not researched yet: Can a Pro user create and save a style that a Free user can then use?
          I hope this helps,
          August
          β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
          [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
            August
            Thanks, I got it verified on the Google group. Yes, all the Pixel-weight Line Styles are present in Free.
            So all that's needed is a source for dashed and/or dotted line styles in various pixel weights that SU Free users can import.
            Anybody got anything like that already built?
            August
            • Mike LuceyM Offline
              Mike Lucey
              Thanks Gjenio, your Tutorial explains the process very well πŸ‘
