    Kerkythea on Mac
    7 Posts 2 Posters 6.6k Views 2 Watching
      liam887
      Hi there just joined. Was wondering if anybody else has had difficulties installing Kerkythea on MAC OSX?
      VISIT MY ONLINE GALLERY
      • jeff hammondJ Offline
        do you have X11 installed?
        (it's an optional install with tiger.. with 10.5, it's standard)
          liam887
          Yeah i installed X11 form my installation disks but still no joy an getting kerek installed, dont even know where to start. Downloaded a tutorial but no luck, might just wait till i upgrade to leopard.
            where are you experiencing problems?
            downloading the app?
            installing the app?
            getting the app to run?
            i have kerky on a laptop running tiger so i don't think leopard will help. it's a weird app though because it's far from being native OS X.. i don't even use it because it looks so ugly πŸ˜„
              liam887
              Ive downloaded the app just no idea how to install and run it? any help would be appreciated, thanks.
                installing it is just like any other app..
                the download (from here) will give you Kerkythea2008.dmg
                mount the disk image and you'll see Kerkythea2008.pkg which is the actual installer... one of these:
                after running the installer, there will be a kerkythea folder in your applications folder
                the sketchup exporter can be downloaded from:
                http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=2
                that will give you a folder called 'su2kt3_05'.. inside that folder is a file named su2kt.rb and a folder named su2kt..
                place those two items in your sketchup plugins folder
                Macintosh HD/library/application support/google sketchup 7 (or 6)/SketchUp/plugins
                there's also a folder called KT lights.. place that in the sketchup components folder:
                Macintosh HD/library/application support/google sketchup 7 (or 6)/SketchUp/Components
                launch SU and kerkythea will be loaded.. the toolbar will probably show up automatically but if not, go (from sketchup's menu bar) View -> Tool Palettes -> SU2Kerkythea
                you may have to launch X11 prior to using kerky but in my case, i don't.. X11 launches automatically
                good luck
                  liam887
                  yeah done it, still not working, think its something to do with my X11, ill try and fix it up when i finish work.
