    Glass Challenge (all render engines)
    148 Posts 47 Posters 40.4k Views 47 Watching
    • boofredlayB
      boofredlay
      Nice Hugo, what app did you use to render?
      • soloS
        Irender NXT
        http://img89.imageshack.us/img89/7100/irenderglassses.jpg
        • H
          HFM
          I went the easy way 😕 Hypershot 😄
          Tried it in Vray, but for some reason it rendered with artifacts
          • marked001M
            marked001
            here are my few maxwell versions... orchids from FormFonts and vase is a free one from TurboSquid.. just did the lighting setup, added the glass material to the vase, and some sss to the petals...
            changed the lighting slightly in each, with multilight... think the last is best... cooked for an hour on low priority, still noisy, but...
            http://img4.imageshack.us/img4/9864/vase4.jpg
            http://img22.imageshack.us/img22/6122/vase4a.jpg
            http://img4.imageshack.us/img4/204/vase4b.jpg
            http://img25.imageshack.us/img25/5384/vase4c.jpg
            http://www.revision21vis.com
            instagram: revi21on
            • EarthMoverE
              EarthMover
              I modeled this very unpractical glass, the liquid, ice cubes and the umbrella in sketchup, then imported into Max and rendered in Vray. In hindsight I should've done more target lighting and not relied on the hdri for reflections. I'm going try again tomorrow.
              Content Creator at Skapeup
              • stefanqS
                stefanq
                v-ray again
                http://img14.imageshack.us/img14/6112/glass03.jpg
                • MarianM
                  Marian
                  2 days old cola
                  • stefanqS
                    stefanq
                    good one Marian!
                    • marked001M
                      marked001
                      here's one more of the vase...
                      http://img15.imageshack.us/img15/9720/vase5a.jpg
                      instagram: revi21on
                      • E
                        Eulgrand
                        Kerkythea again, and this time I could manage to get caustics...
                        SU6
Kerkythea 2008 Echo - MLT (BPT) 195 passes
                        • C
                          Connor
                          There are a lot of fantastic images here. It's making me want to keep trying. So I did another one with Sketchup and Kerkythea. Again, there's some post-production done - cropping, levels, a little bit of glow.
                          I find that I'm having a little trouble modeling the tops of the glasses right. They look too wide. Does anyone have any advice on that front?
                          SU 6 and Kerkythea
                            andeciuala
                            here go mine, actuly this is a little old study, but i'm so busy, and i'd like so mutch to participate, here we go.
                            Sketchup model, i just used other software to map the glossiness map, sketchup could not do it, and make the ice to add the noise on it, sketchup could do it but would take too mutch time. Rendered in vray for sketchup.
                            cheers
                            http://img219.imageshack.us/img219/5031/copogotasuk7.jpg
                            http://img20.imageshack.us/img20/273/copocopyon9.jpg
                            • C
                              Crazy Eyes
                              I thought that I might put in an entry too. Hypershot if you couldn't have guessed.
                              Some people are lovers, some are fighters, if you love to fight, fight for love!
                                stereofidelic
                                I really love this one. Could you tell me what materials did you use? This is really great render.
                                  andeciuala
                                  I think this is the best kerkythea render i've seen, actuly i didn't know that kerkythea could get such results.
                                  • T
                                    teofas
                                    eulgrand and ande, both made an excellent work, congrats
                                    yep me too one of the best renders with kerky, congrats!!
                                    http://www.spazioarquitectura.com
                                      andre51
                                      ..and Maxwell...
                                      • C
                                        cadmunkey
                                        Another attempt, a homage to my favourite tipple although the colour still needs tweaking..
                                        • E
                                          Eulgrand
                                          Thanks for the kind comments 😳
                                          My materials are :
                                          Glass : ref. "G1" from the Basic Glasses library (Donwload section of KT's forum)
                                          Water : ref. "H5" from the same library
                                          For them 2, the material type is Dielectric / Glass, reflection & refraction set to color/Pure white, and IoR resp. 1.52 and 1.33
                                          Whiskey :
                                          Material type : Dielectric / Glass
                                          Refraction : RGB values set to (242,153,61) and IoR 1.359
                                          Reflection : copy/paste the refraction color and set the saturation to 20
                                          The stirrer is a basic plastic, not too glossy (shininess 30 and IoR 1.60)
                                          The scene is illuminated by two emitting umbrellas on each side of the camera, one little emitting square to generate caustics, and a global for more reflections on the glasses.
                                          Now that I have my technical settings, I'll try to make a real scene like those I could see above (Connor, Ande, Andre...) with nicer glasses !
                                          • daleD
                                            dale
                                            Had to have a shot at this too. (Kerkythea)
                                            • 3 / 8
