    Glass Challenge (all render engines)
    148 Posts 47 Posters 25.1k Views 47 Watching
    • 2 Offline
      21D
      @gaganraj said:
      boof-
      how are you liking modo? nice renders!
      Thanks. I like it. I still have much to learn but yes, I really like it.
      Oh, and all the textures I used were created directly in Modo. Modeling in SU.
      hi there Boo, i was wondering if you could help me out with MODO.....
      i have recently begun to use Modo and this is my result so far
      glass in MODO
      As you can see, my glass and liquid material are not so good
      and seeing that you got that part down, would you mind helping me out??
      i've only been using Modo for 2 days now....and personaly i find it a very good software....and i had no trouble yet with the transition from SU to MODO...but hey it's only been 2 days 😄 , never know what's ahead. 👍
      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
      Le Corbusier
      • boofredlayB Offline
        boofredlay
        Rachild, rather than me trying to explain it all, check out this tutorial thread on the Modo forum. I basically followed it then did some tweaking of my own.
        http://forums.luxology.com/discussion/topic.aspx?id=16060
        • H Offline
          HFM
          Well, here's my try 😄... Not totally realistic but I'm pleased with the result
            boofredlay
            Nice Hugo, what app did you use to render?
            • soloS Offline
              Irender NXT
              http://img89.imageshack.us/img89/7100/irenderglassses.jpg
              • H Offline
                HFM
                I went the easy way 😕 Hypershot 😄
                Tried it in Vray, but for some reason it rendered with artifacts
                • marked001M Offline
                  marked001
                  here are my few maxwell versions... orchids from FormFonts and vase is a free one from TurboSquid.. just did the lighting setup, added the glass material to the vase, and some sss to the petals...
                  changed the lighting slightly in each, with multilight... think the last is best... cooked for an hour on low priority, still noisy, but...
                  http://img4.imageshack.us/img4/9864/vase4.jpg
                  http://img22.imageshack.us/img22/6122/vase4a.jpg
                  http://img4.imageshack.us/img4/204/vase4b.jpg
                  http://img25.imageshack.us/img25/5384/vase4c.jpg
                  http://www.revision21vis.com
                  instagram: revi21on
                  • EarthMoverE Offline
                    EarthMover
                    I modeled this very unpractical glass, the liquid, ice cubes and the umbrella in sketchup, then imported into Max and rendered in Vray. In hindsight I should've done more target lighting and not relied on the hdri for reflections. I'm going try again tomorrow.
                    Content Creator at Skapeup
                    • stefanqS Offline
                      stefanq
                      v-ray again
                      http://img14.imageshack.us/img14/6112/glass03.jpg
                      • MarianM Offline
                        Marian
                        2 days old cola
                        • stefanqS Offline
                          stefanq
                          good one Marian!
                            marked001
                            here's one more of the vase...
                            http://img15.imageshack.us/img15/9720/vase5a.jpg
                            instagram: revi21on
                            • E Offline
                              Eulgrand
                              Kerkythea again, and this time I could manage to get caustics...
                              SU6
Kerkythea 2008 Echo - MLT (BPT) 195 passes
                                Connor
                                There are a lot of fantastic images here. It's making me want to keep trying. So I did another one with Sketchup and Kerkythea. Again, there's some post-production done - cropping, levels, a little bit of glow.
                                I find that I'm having a little trouble modeling the tops of the glasses right. They look too wide. Does anyone have any advice on that front?
                                SU 6 and Kerkythea
                                  andeciuala
                                  here go mine, actuly this is a little old study, but i'm so busy, and i'd like so mutch to participate, here we go.
                                  Sketchup model, i just used other software to map the glossiness map, sketchup could not do it, and make the ice to add the noise on it, sketchup could do it but would take too mutch time. Rendered in vray for sketchup.
                                  cheers
                                  http://img219.imageshack.us/img219/5031/copogotasuk7.jpg
                                  http://img20.imageshack.us/img20/273/copocopyon9.jpg
                                    Crazy Eyes
                                    I thought that I might put in an entry too. Hypershot if you couldn't have guessed.
                                    Some people are lovers, some are fighters, if you love to fight, fight for love!
                                      stereofidelic
                                      I really love this one. Could you tell me what materials did you use? This is really great render.
                                        andeciuala
                                        I think this is the best kerkythea render i've seen, actuly i didn't know that kerkythea could get such results.
                                          teofas
                                          eulgrand and ande, both made an excellent work, congrats
                                          yep me too one of the best renders with kerky, congrats!!
                                          http://www.spazioarquitectura.com
                                            andre51
                                            ..and Maxwell...
                                            • 3 / 8
