    Glass Challenge (all render engines)
    148 Posts 47 Posters 40.4k Views 47 Watching
    • P
      Puma
      Ok, so the right one really isn't a photo? Only the background reminds me of a render..
      • boofredlayB
        boofredlay
        SU + Modo
        • EarthMoverE
          EarthMover
          Cheers Boo! Looks awesome!
          Content Creator at Skapeup
          • T
            teofas
            great render boo, really nice!
            http://www.spazioarquitectura.com
            • C
              Connor
              So here's my try - sketchup and kerkythea.
              A little bit of level adjusting and cropping done post-pro.
              Still grainy.
              • boofredlayB
                boofredlay
                Thanks Adam, thanks teofas.
                Here are some more SU + Modo.
                Before the Peppercorn Ranch:
                After the Peppercorn Ranch:
                • G
                  gaganraj
                  boof-
                  how are you liking modo? nice renders!
                    stereofidelic
                    The only photoshop on the both photos is adjustments of brightness and contrast .
                    • boofredlayB
                      boofredlay
                      @gaganraj said:
                      boof-
                      Thanks. I like it. I still have much to learn but yes, I really like it.
                      Oh, and all the textures I used were created directly in Modo. Modeling in SU.
                        21D
                        @gaganraj said:
                        boof-
                        hi there Boo, i was wondering if you could help me out with MODO.....
                        i have recently begun to use Modo and this is my result so far
                        glass in MODO
                        As you can see, my glass and liquid material are not so good
                        and seeing that you got that part down, would you mind helping me out??
                        i've only been using Modo for 2 days now....and personaly i find it a very good software....and i had no trouble yet with the transition from SU to MODO...but hey it's only been 2 days ๐Ÿ˜„ , never know what's ahead. ๐Ÿ‘
                        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                        Le Corbusier
                        • boofredlayB
                          boofredlay
                          Rachild, rather than me trying to explain it all, check out this tutorial thread on the Modo forum. I basically followed it then did some tweaking of my own.
                          http://forums.luxology.com/discussion/topic.aspx?id=16060
                          • H
                            HFM
                            Well, here's my try ๐Ÿ˜„... Not totally realistic but I'm pleased with the result
                            • boofredlayB
                              boofredlay
                              Nice Hugo, what app did you use to render?
                              • soloS
                                Irender NXT
                                http://img89.imageshack.us/img89/7100/irenderglassses.jpg
                                • H
                                  HFM
                                  I went the easy way ๐Ÿ˜• Hypershot ๐Ÿ˜„
                                  Tried it in Vray, but for some reason it rendered with artifacts
                                  • marked001M
                                    marked001
                                    here are my few maxwell versions... orchids from FormFonts and vase is a free one from TurboSquid.. just did the lighting setup, added the glass material to the vase, and some sss to the petals...
                                    changed the lighting slightly in each, with multilight... think the last is best... cooked for an hour on low priority, still noisy, but...
                                    http://img4.imageshack.us/img4/9864/vase4.jpg
                                    http://img22.imageshack.us/img22/6122/vase4a.jpg
                                    http://img4.imageshack.us/img4/204/vase4b.jpg
                                    http://img25.imageshack.us/img25/5384/vase4c.jpg
                                    http://www.revision21vis.com
                                    instagram: revi21on
                                    • EarthMoverE
                                      EarthMover
                                      I modeled this very unpractical glass, the liquid, ice cubes and the umbrella in sketchup, then imported into Max and rendered in Vray. In hindsight I should've done more target lighting and not relied on the hdri for reflections. I'm going try again tomorrow.
                                      • stefanqS
                                        stefanq
                                        v-ray again
                                        http://img14.imageshack.us/img14/6112/glass03.jpg
                                        • MarianM
                                          Marian
                                          2 days old cola
                                          • stefanqS
                                            stefanq
                                            ๐Ÿ˜†
                                            good one Marian!
                                            • 2 / 8
