    Glass Challenge (all render engines)
    148 Posts 47 Posters 40.4k Views 47 Watching
      rcossoli
      that good examples
      I hope I can make one too with kerkythea
      fred ... very good these images
      THREEDIMENSIONSWEB dot COM
      • EscapeArtistE
        EscapeArtist
        Very nice! Where's the cheese and fruit tray?
        OK, here's my entry. I thought the glass was OK, but the paper mat stumped me. Couldn't figure how to make decent paper, and I forgot to chamfer the edge of the mat.
        Oh, well; glass of whiskey anyone?
        EDIT: Forgot to mention - Sketchup + Kerkythea
          stereofidelic
          These are 2 tests in Kerkythea.
          • P
            Puma
            Ok, so the right one really isn't a photo? Only the background reminds me of a render..
            • boofredlayB
              boofredlay
              SU + Modo
              • EarthMoverE
                EarthMover
                Cheers Boo! Looks awesome!
                Content Creator at Skapeup
                • T
                  teofas
                  great render boo, really nice!
                  http://www.spazioarquitectura.com
                  • C
                    Connor
                    So here's my try - sketchup and kerkythea.
                    A little bit of level adjusting and cropping done post-pro.
                    Still grainy.
                    • boofredlayB
                      boofredlay
                      Thanks Adam, thanks teofas.
                      Here are some more SU + Modo.
                      Before the Peppercorn Ranch:
                      After the Peppercorn Ranch:
                      • G
                        gaganraj
                        boof-
                        how are you liking modo? nice renders!
                          stereofidelic
                          The only photoshop on the both photos is adjustments of brightness and contrast .
                          • boofredlayB
                            boofredlay
                            @gaganraj said:
                            boof-
                            Thanks. I like it. I still have much to learn but yes, I really like it.
                            Oh, and all the textures I used were created directly in Modo. Modeling in SU.
                              21D
                              @gaganraj said:
                              boof-
                              hi there Boo, i was wondering if you could help me out with MODO.....
                              i have recently begun to use Modo and this is my result so far
                              glass in MODO
                              As you can see, my glass and liquid material are not so good
                              and seeing that you got that part down, would you mind helping me out??
                              i've only been using Modo for 2 days now....and personaly i find it a very good software....and i had no trouble yet with the transition from SU to MODO...but hey it's only been 2 days 😄 , never know what's ahead. 👍
                              "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                              Le Corbusier
                              • boofredlayB
                                boofredlay
                                Rachild, rather than me trying to explain it all, check out this tutorial thread on the Modo forum. I basically followed it then did some tweaking of my own.
                                http://forums.luxology.com/discussion/topic.aspx?id=16060
                                • H
                                  HFM
                                  Well, here's my try 😄... Not totally realistic but I'm pleased with the result
                                  • boofredlayB
                                    boofredlay
                                    Nice Hugo, what app did you use to render?
                                    • soloS
                                      Irender NXT
                                      http://img89.imageshack.us/img89/7100/irenderglassses.jpg
                                      • H
                                        HFM
                                        I went the easy way 😕 Hypershot 😄
                                        Tried it in Vray, but for some reason it rendered with artifacts
                                        • marked001M
                                          marked001
                                          here are my few maxwell versions... orchids from FormFonts and vase is a free one from TurboSquid.. just did the lighting setup, added the glass material to the vase, and some sss to the petals...
                                          changed the lighting slightly in each, with multilight... think the last is best... cooked for an hour on low priority, still noisy, but...
                                          http://img4.imageshack.us/img4/9864/vase4.jpg
                                          http://img22.imageshack.us/img22/6122/vase4a.jpg
                                          http://img4.imageshack.us/img4/204/vase4b.jpg
                                          http://img25.imageshack.us/img25/5384/vase4c.jpg
                                          http://www.revision21vis.com
                                          instagram: revi21on
                                          • EarthMoverE
                                            EarthMover
                                            I modeled this very unpractical glass, the liquid, ice cubes and the umbrella in sketchup, then imported into Max and rendered in Vray. In hindsight I should've done more target lighting and not relied on the hdri for reflections. I'm going try again tomorrow.
                                            • 2 / 8
