    Glass Challenge (all render engines)
    148 Posts 47 Posters 40.4k Views 47 Watching
    • EscapeArtistE
      EscapeArtist
      Very nice! Where's the cheese and fruit tray?
      OK, here's my entry. I thought the glass was OK, but the paper mat stumped me. Couldn't figure how to make decent paper, and I forgot to chamfer the edge of the mat.
      Oh, well; glass of whiskey anyone?
      EDIT: Forgot to mention - Sketchup + Kerkythea
        stereofidelic
        These are 2 tests in Kerkythea.
        • P
          Puma
          Ok, so the right one really isn't a photo? Only the background reminds me of a render..
          • boofredlayB
            boofredlay
            SU + Modo
            • EarthMoverE
              EarthMover
              Cheers Boo! Looks awesome!
              Content Creator at Skapeup
              • T
                teofas
                great render boo, really nice!
                http://www.spazioarquitectura.com
                • C
                  Connor
                  So here's my try - sketchup and kerkythea.
                  A little bit of level adjusting and cropping done post-pro.
                  Still grainy.
                  • boofredlayB
                    boofredlay
                    Thanks Adam, thanks teofas.
                    Here are some more SU + Modo.
                    Before the Peppercorn Ranch:
                    After the Peppercorn Ranch:
                    • G
                      gaganraj
                      boof-
                      how are you liking modo? nice renders!
                        stereofidelic
                        The only photoshop on the both photos is adjustments of brightness and contrast .
                        • boofredlayB
                          boofredlay
                          @gaganraj said:
                          boof-
                          Thanks. I like it. I still have much to learn but yes, I really like it.
                          Oh, and all the textures I used were created directly in Modo. Modeling in SU.
                            21D
                            @gaganraj said:
                            boof-
                            hi there Boo, i was wondering if you could help me out with MODO.....
                            i have recently begun to use Modo and this is my result so far
                            glass in MODO
                            As you can see, my glass and liquid material are not so good
                            and seeing that you got that part down, would you mind helping me out??
                            i've only been using Modo for 2 days now....and personaly i find it a very good software....and i had no trouble yet with the transition from SU to MODO...but hey it's only been 2 days 😄 , never know what's ahead. 👍
                            "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                            Le Corbusier
                            • boofredlayB
                              boofredlay
                              Rachild, rather than me trying to explain it all, check out this tutorial thread on the Modo forum. I basically followed it then did some tweaking of my own.
                              http://forums.luxology.com/discussion/topic.aspx?id=16060
                              • H
                                HFM
                                Well, here's my try 😄... Not totally realistic but I'm pleased with the result
                                • boofredlayB
                                  boofredlay
                                  Nice Hugo, what app did you use to render?
                                  • soloS
                                    Irender NXT
                                    http://img89.imageshack.us/img89/7100/irenderglassses.jpg
                                    • H
                                      HFM
                                      I went the easy way 😕 Hypershot 😄
                                      Tried it in Vray, but for some reason it rendered with artifacts
                                      • marked001M
                                        marked001
                                        here are my few maxwell versions... orchids from FormFonts and vase is a free one from TurboSquid.. just did the lighting setup, added the glass material to the vase, and some sss to the petals...
                                        changed the lighting slightly in each, with multilight... think the last is best... cooked for an hour on low priority, still noisy, but...
                                        http://img4.imageshack.us/img4/9864/vase4.jpg
                                        http://img22.imageshack.us/img22/6122/vase4a.jpg
                                        http://img4.imageshack.us/img4/204/vase4b.jpg
                                        http://img25.imageshack.us/img25/5384/vase4c.jpg
                                        http://www.revision21vis.com
                                        instagram: revi21on
                                        • EarthMoverE
                                          EarthMover
                                          I modeled this very unpractical glass, the liquid, ice cubes and the umbrella in sketchup, then imported into Max and rendered in Vray. In hindsight I should've done more target lighting and not relied on the hdri for reflections. I'm going try again tomorrow.
                                          • stefanqS
                                            stefanq
                                            v-ray again
                                            http://img14.imageshack.us/img14/6112/glass03.jpg
                                            • 2 / 8
