    Modeling a meniscus difficulty
    14 Posts 4 Posters 1.6k Views 4 Watching
    • EscapeArtistE
      EscapeArtist
      Jeff,
      I'm not sure how to go about creating a smoother transition in the meniscus to the glass other than SD&S. Perhaps I'm running up against the limitations of Sketchup for this particular operation. I'd like to use a smaller poly count, but unfortunately with the rendering engine I'm using, (AFAIK, in my limited knowledge anyway...) Kerkythea offers no method of smoothing other than vertex weld and loop subdivision along with a "smooth" setting - all of which were applied to both models in the screenshots above - so almost all of the geometry and smoothing needs to be done in Sketchup before exporting to the rendering software.
      Maybe I'm misunderstanding the direction you are pointing? I'm all ears for ideas!
      • jeff hammondJ
        to me, it looks like your selecting the wine glass and then clicking on the second icon in whaat's subdivide and smooth.
        if that's the case, you're not smoothing anything, you're just doing the same thing as the example i posted above.. dividing the area into smaller pieces but not moving any of the actual vertices/geometry around.
        i'm not familiar with any of the kerkythea setting you're talking about so maybe someone else can comment on that..i'm just talking about the sketchup screenshot you've posted..
        if kerky takes the newly created lines from the sds operation and actually moves them around then it actually sounds ok. but again, i'm unfamiliar with the app so hopefully someone can clear thing up for you instead of adding to the confusion like me πŸ˜„
        [add]
        here's a sphere:
        same sphere that's been subdivided via sds's 2nd icon: (notice it's not any smoother.. just more lines)
        same sphere that's been subdivided and smoothed: (it's more/less round now)
        • EscapeArtistE
          EscapeArtist
          I see what you were saying... No, I'm definitely using the first function, the "ball in the box" icon in SD&S. It does add a lot of geometry though.
          • T
            Teezer
            One of the things that you can do after the Subdivide & Smooth operation is to manually remove unnecessary geometry that was created in areas that remain flat, like the surface of the liquid in the glass.
            Otherwise, there are lots of rendering experts on this board (I'm not one of them), so I'd recommend that you upload your model and have one of them give it a look.
            Real life is just another website, albeit a rather boring one.
            • jeff hammondJ
              ok then.
              i think the problem is that you're drawing the glass and wine together and then subdividing it as one.. it's causing a similar problem as trying to subdivide a cube that has a plane inside..
              [example]
              this:
              leads to this:
              try subdividing the glass first then adding the wine/meniscus after. you probably won't have to subdivide the wine.. just draw the profile of the surface and meniscus and followme it according to one of the newly subdivided lines on the glass.
              try rendering this skp to see if it helps.. it actually looks a lot like the first example you posted but i'm just curious now.
              wineglass.skp
              • EscapeArtistE
                EscapeArtist
                I'll absolutely try your suggestions, these sound like great ideas. I'm unfortunately on the road using a linux laptop that refuses to let me run Sketchup, so I'll have to wait until I get home in a few days.
                • EscapeArtistE
                  EscapeArtist
                  OK, I tried a couple of variations on both suggestions to see what would work. I believe it has resulted in a quite respectable, but not perfect, meniscus. This is definitely a Sketchup limitation, it's more suited to to the mechanical rather than the organic, but can do a passing representation with some futzing. There are very minor flaws at the junction of the liquid and glass, but unless the fluid/glass intersection is the focus of your work, I don't think it's so noticeable.
                  Anyway, here's the steps I took if anyone would like to do something similar:
                  1. Create the glass
                  2. Smooth the glass with SD&S
                  3. View hidden geometry
                  4. Use the pencil tool on the planar edges, at the liquid's level you want, to create the surface
                  5. Select the liquid and create a component
                  6. Open the component and use the SD&S crease tool on each segment of the edge
                  7. Now, start creating the meniscus by using the tool to create two concentric rings on the surface, one very close to the edge, and one a slightly greater distance to the center. If you look at a meniscus, it appears much thinner and has a larger radius as it approaches the edge than it does towards the center.
                  8. Select the inner surface and the first ring and pull it straight down using the tool whatever distance looks good to you
                  9. Now select only the center surface and pull it down a shorter amount than the previous.
                  10. Apply SD&S to all surfaces in the liquid surface group
                  11. When SD&S gets done, explode the component. When I made this particular model, I had to re-attach every other vertex of the liquid's edge to the surface of the glass. Making the model about 10x larger than life size will help a lot in seeing and moving the verticies, and making the hidden geometry visible will help too.
                  12. Export and render.
                  I used Kerkythea and applied a basic dielectric glass to the glass model and the liquid, changed the liquid color to red in order to see the meniscus better, and changed the liquid's index of refraction to 1.3 (water). Results are below.
                  Thanks for the help!
                  • david_hD
                    david_h
                    what a weird coincidence. I was just in the process of modeling a goldfish bowl and was trying to figure out how to model/render the water as opposed to the bowl. Cuz it just wasn't working for me.!
                    Thanks for the TUT!
                    • T
                      Teezer
                      Excellent results! Persistence pays off... πŸ˜„ πŸ‘
                      • EscapeArtistE
                        EscapeArtist
                        Thanks for the TUT!
                        Made my day reading that it helped out, glad to be of assistance. Thanks again to everyone for the suggestions.
                        EDIT: I'd be happy to make a video of it, what software does everyone use to make those neat video tuts? Is it free?
