    Sketchup.version vs. Sketchup.version_number
    9 Posts 4 Posters 717 Views 4 Watching
    • H Offline
      HPW
      Why different results:
      Sketchup.version
      7.0.10247
      7000999
        Error 404 (Not Found)!!1
        (code.google.com)
        Sketchup.version
        Gets the current version of sketchup in decimal form
        (code.google.com)
        Get the current version of sketchup as a whole number for comparisons
          remus
          Thomthom, i think version_number is just meant to return the SU version without the decimal points. At least thats how it works in SU6.
          I'm guessing it's a bug πŸ‘
            You sure? I'm not seeing that.
            SU6:
            6004112
            SU7:
            7000999
            version_number number returns an integer (whole number), while version returns a string.
              remus
              Probably my ruby noobishness showing through there.
              I was referring to the numbers themselves (conveniently ignoring a few zeroes as well.)
              In SU6:
              version gives 6.4.112
              version_number gives 6004112
              in SU7:
              version gives 7.0.10247
              version_number gives 7000999
              So going by what SU6 gives i would have thought SU7 would have given 700010247.
              I wonder if it's something to do with version_number being limited to 7 figures? i.e. it gets to 999 but cant go any further.
                Yea, I think it might be worth mentioning this to the SU team.
                • H Offline
                  HPW
                  Does they read it here, or must someone take more action/bug report?
                    They are around on the forum. Not sure if it'll be seen on this section though. More likely if it's put into the Bug section. The Ruby section might work as well, but there's so many posts there everyday that they might get lost in the mass.
                    • AndrewSA Offline
                      AndrewS
                      The problem occurred when the last component of our version number exceeded 3 digits in length. That's why SU6 (.112) works, while SU7 (.8656, .10247, etc.) doesn't. We have an open bug for this issue.
                      Andrew S.
                      SketchUp Release Engineer
