    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 866.4k Views 667 Watching
      Welcome Dor and nice to see you dropping by to say hello.
      Best would be however to post your specific Podium question in the "Extensions" forum where I'm sure it would receive more attention than "buried" in this long topic here.
        dcoop58
        Hi, just joined the group!
        Been using the free version for awhile, just installed V7 pro. 😎
        Started using SliceModeler 1.4 to make physical models....
        It's Technical...............
          remus
          Hi david. Those physical models sound rather intriguing, howd you go about cutting out the slices after youve cut up the SU model? Is it a case of printing out templates and using them to cut your slices or have you found a more elegant solution?
            johnmw1
            Just passing through and having a look around. Not too sure if this is what I'm looking for or not. I have a small assignment I have to complete for college which asks for a sketch layout of an isolated campsite. It has to take into consideration environmental and safety issues and how I would lay the camp out etc. I'm guessing that no one else in my class would have thought of using this option, and I'm sure or hoping it would help with my grading also. πŸ˜‰
            Now I'm guessing all that is really required is just a plain line drawing, and I was considering letting my 9yr old daughter draw it for me as I have absolutely no drawing skills whatsoever. Then it dawned on me in the middle of the night that there are programmes such as these, but whoa I can see that I'm already out of my depth and that there maybe quite a steep learning curve just to achieve a very simple drawing.
            My biggest hurdle is simply time, I just don't have the time to take on something else to learn, I'm totally crammed now.
            Is this the right type of programme for me, or is there something else out there?
            Cheers
            John
              remus
              Sounds like sketchup is the programme for you, it's learning curve is relatively shallow πŸ‘
              Feel free to start a thread if you need any specific help.
              • jcharltoncarpJ Offline
                jcharltoncarp
                My name is John. I've been taking advantage of the current economic down turn, to, amongst other things learn Sketchup. The reason I joined the forum is my interest in Fredo's amazing freescale tool. I'm using a Mac running Leopard and have been unable to install the downloads correctly in my plugins folder. I was wondering if someone could post a screen shot of the folder hierarchy properly installed? I have been following the posts on the Ruby forum and have tried several ways to do the installation, but no joy. All suggestions gratefully accepted.
                Thanks John
                  Hi John and welcome. Unfortunately I don't know the ins and outs of the Mac but I'm sure someone will be able to give a hand. Did you also post your question in the Runy forum?
                    johnmw1
                    Hi Remus,
                    Yes I probably will have to ask for lots of help. πŸ‘ I guess the first question is where do I start, or how do I start?
                    Cheers
                    John
                      Hi John,
                      "Stuck" up to the top of this forum is the "Getting started" topic. There there are links to various resources to video tutorials, the SU manual etc.
                      They are great places to start at (however back a fe years ago, when I started, I just started with doodling around and only went to the resources when I found out that SU may know more than I can imagine).
                        johnmw1
                        @gaieus said:
                        Hi John,
                        Hi Gai,
                        Thanks for that, I was just having a quick look around, and now I'm beginning to think if this is really what I'm trying to do. Basically all I want is a plan drawing of a campsite with some trees scattered around, a campfire, a caravan, an outhouse, and an area for 3 4WD vehicles plus a few other bits and pieces added to it all to make it look like a remote campsite. Something that I will be able to print out and present as part of my assignment. I just feel I'm getting over my head for the so little time that I have.
                        But I will go and have a look at getting started as you suggested and see what I can come up with.
                        Cheers
                        John
                          If you only want to "shovel" a couple of items like that together, you may want to ahe a look at the 3D Warehouse, download the necessary models and arrange them around. There are all the trees, campfires, tents, caravans, vehicles there...
                            johnmw1
                            Thanks Gai, I shall go and have a look straight away, and yes I think you're right, I just want to put a few things together so I can get this assignment going. πŸ˜„
                            Cheers
                            John
                              johnmw1
                              Just had a look at 3D Warehouse, also D/L SU7, had a very quick play and also D/L a 3D caravan, but that's where I have got lost, I don't know how to scale it down etc etc,
                              Cheers
                              John
                                Why would you want to scale it down? Most probably (unless you are very unlucky),it is to-scale; i.e. 1:1.
                                Note that this is a virtual world so there's no reason to scale down/up anything (with rare exceptions not worth mentioning here) if you can work "in real world scale". Otherwise we would always find out what the original scale was and need to scale everything all the time.
                                How about zooming out with the scroll wheel instead?
                                  remus
                                  Select the caravan components->tools->scale then click the corner handles πŸ‘
                                  edit: you beat me to it gai.
                                    No,I had different suggestions πŸ˜‰
                                      johnmw1
                                      Thanks Remus & Gai for your help. Bottom line for me is I think it's just too much for me to take in and learn up on, I just don't have the time. I know you get nothing for nothing in this world and given another time(or more time)I would be only too happy to listen and learn, but my plate is pretty full at the moment. I will just have to be happy to let my 9yr old draw it freehand for me. 😳
                                      Cheers
                                      John
                                        jcharltoncarp
                                        Thanks Gaieus,
                                        I'll repost to ruby. I've got enough learning to get through for now, but as a carpenter I will need to join the woodworking board soon.
                                        Thanks again John
                                          @jcharltoncarp said:
                                          ...as a carpenter I will need to join the woodworking board...
                                          I have add you to that usergroup so you should be able to see it / post in there.
                                            dcoop58
                                            We have in our shop a 5 axis mill driven off of Surfcam software. I export a .dxf file of the sections into Surfcam and then we cut the sections out of 5mm foam core.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 72
                                            • 73
                                            • 17 / 73
