    PDF export bug? Includes example figures
    39 Posts 7 Posters 7.8k Views 7 Watching
      @gaieus said:
      Also, AFAIK only the Mac can export vector based pdf even from SU, isn't that correct?
      Incorrect, at least for SU. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=16156&st=0&sk=t&sd=a&start=15#p130313
      Not sure about LO. I have a Mac, but not with Pro version.
        midlana42
        Wait... you're saying the "PDF" from LO is actually a PNG? Comparing the outputs it looks better than PNG, or maybe I'm imagining things.
          Yes. It's not vector, it's a bitmap. So it'd be the same as exporting a 2D bitmap and wrapping it in a PDF.
          I don't know what it is that looks better. To me it looks the same. Might you not have exported in large enough resolution when you have previously tried PNG?
          You're not comparing against a JPEG where you might see the compression artefacts?
          • GaieusG
            OK, my bad. I haven't had the need yet to export to vector pdf. Thanks anyway.
            • AnssiA
              Anssi
              SU exports only vector PDFs, to get a raster PDF you will have to print using some PDF printer and with "Use High-accuracy HLR" DISabled.
              Layout can export either vector or bitmap, and also a hybrid file (with vector lines on top of the bitmap textures and shadows).
              Anssi
                remus
                Had a quick go at importing an SU PDF in to photoshop and it had to rasterize it first, which would suggest your right anssi.
                  Photoshop will always rasterize PDFs. Try Illustrator instead.
                    remus
                    Ive only got photoshop πŸ˜‰
                    More anecdotal evidence: no textures were exported (only shading) which would be a bit weird if the PDF was an image within a PDF.
                      midlana42
                      Anssi
                      What do I have to specify in LO in order to export the vector type only? I'm making possibly a big assumption that LO's vector PDF exporter is different (bug-free) than SU's...
                      • AnssiA
                        Anssi
                        In Layout, you can select the view and set it's rendering style in the Sketchup Model "tab" in the Tray
                        It is hardly helpful, but the problem is, I understand, that all hidden line algorithms have to limit their accuracy, because they cannot keep caculating indefinitely. So always some lines that are directly on a surface are interpreted as hiding behind it, leading to missed lines. Besides SU PDF and DWG exports, I have seen the same with hidden-line exports from Autocad too. I have not tried if it is the same with Archicad and Revit too.
                        Anssi
                        • 2 / 2
