    Hover box
    11 Posts 5 Posters 1.2k Views 5 Watching
    • W
      Wacov
      Very simple, the box has 4 no-collision objects connected through a spring. These objects have 'push(10)' in their onTouch field, so the box appears to, and, technically, does hover just above the ground. Using hidden no-collision geometry in the bouyancy field lets the box hover over it, while other objects act normally. It's also able fly smoothly over bumps. I'll probably be basing my entry to Hobbnob's contest on this; if anyone else uses it... well, we know where they got it from πŸ˜‰
      Not controllable... yet
      • H
        hobbnob
        thanks for considering my challenge wacov, very good design too
        My WIP Thread:Here
          MrPlanet
          That's brilliant!
          I suggest you keep refining it.
          πŸ‘
          I reject your reality and substitute my own.
          • B
            BTM
            Good! I've been going for something fairly similar, but automated. It doesn't use springs, but does use the ontouch function in a way. I'm currently figuring out how to get it to do what I want it to, and am getting closer πŸ˜‰
            ...Also, what challenge?
            • B
              BTM
              3 posts in a minute... πŸ˜†
              • H
                hobbnob
                gotta be a record surely
                My WIP Thread:Here
                • P
                  Physicsguy1
                  I'll use this on my sled. Is that OK?
                  • W
                    Wacov
                    Sure; mine will eventually be very different to this version. BTM, the challenge is Hobbnob's, link's in his signature.
                    Lol... and I went offline once I posted it 😳
                    • W
                      Wacov
                      Now controllable, with an actual body. It's simple, and works well... and keyboard will be just fine, although joysticks are better.
                      Hover prototype.skp
                      • H
                        hobbnob
                        pretty damn good wacov, well done!
                        My WIP Thread:Here
                          MrPlanet
                          I've gone for something a little different. It uses OnTouch and a fixed vibrator to let it go up vertical slopes.
