Cannot move face...
"...face touching at corner must be a triangle"
See attached. Try to move that end face (or the other one at the origin).
I have never seen such a "tooltip" (as far as I remember).Before:
- I made and arc,
- scaled a copy down
- closed ends to fill face
- pushpulled to thickness
- moved this face upwards to create a "slanting ramp"
- flipped acouple of edges to make the surface nicer
Thats good one Gaieus! Never seen that error before.
And can you move either of the faces? They seem to have gotten stuck in space.
They are not glued (also, in this case you should be able to move them aside). -
If you explode the arches the faces will move.
Seems that SU doesn't want to break arches. -
hmm... Odd that they could be moved the first time...
I say: Voodoo
You've been playing with dark magic again Gaieus -
No, this is a normal, easy way to build those ramps: just move the face upwards (sometimes you have to fiddle with autofold afterwards but that's okay) like in the attached below (here I "pre-fixed" the autofold lines for easier example).
You know what, I think I've run across this before when I'd done just that, trying to create a ramp. Just jugged my memory.
