    Sketchup 7 Update - is the UV map bug fixed?
    6 Posts 4 Posters 1.3k Views 4 Watching
    • P
      PRSS
      Hello everybody!
      The first SketchUP 7 had some bugs when textured materials were applied. The UV mapping was not constant or something like that. Is the bug fixed in the updated version OF SketchUP 7?
      • Chris FullmerC
        You might have to get more specific. I'm not recalling the exact problem. Did it probably have something to do with exporting the model for rendering?
        • AndrewSA
          AndrewS
          Yep, specifics would be good. None of the developers here know what this issue is about...
          Andrew
          Andrew S.
          SketchUp Release Engineer
          • P
            PRSS
            Sorry for the short description. The problem with the first SU7 was:
            If you picked a texture and applied it to an object, then edited/ re-positioned/re-oriented the texture for that object, and then if you kept on applying the same texture to other objects/faces, sometimes the modified "UV mapping" is forgotten by SU and reverts back to the original texture. I came across this once, and since this problem was also discussed by someone else also in the forums, I just gave up SU7 and reverted back to SU6. I would like to switch to SU7 once for all. Hence I am asking this question. I have downloaded this maintenance update. I have used it a few times and I am quite happy with it. I am just curious to know if this bug (which seems to have existed) is fixed.
            Thanks in advance
            With best regards
            PRSS
              richcat
              I might be wrong but is this what you are referring to - reported in bugs section?
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=14485 (but no replies)
              or perhaps
              404 Not Found
              (www.sketchucation.com)
              • P
                PRSS
                Thank you very much richcat! It was exactly that. I have been searching for this intermittently for the last two hours or so.
                With best regards
                PRSS
