    SP3x. The Plan.
    21 Posts 7 Posters 3.3k Views 7 Watching
    • W Offline
      Wacov
      Ah ๐Ÿ˜„ we both had it too, but I think we both reinstalled it ๐Ÿ˜„ No worries, SP3 X is just a few days away...
      • H Offline
        hobbnob
        yeah in a few days we shall be in a state of pure elation ๐Ÿ˜
        My WIP Thread:Here
        • W Offline
          Wacov
          I dunno; I think that cone's watching me...
          • H Offline
            hobbnob
            things are going to be proper advanced with things like that, just imagine: tracking turrets, missiles etc, automatic dogfighting aircraft that jink if hit, imagine the possibilities!!
            My WIP Thread:Here
              Platypus5
              When will the final version of SP3 be released?
              • W Offline
                Wacov
                I think technically this is the final version. SP3 X is actually separate, since models made with it probably won't work in SPIV.
                • H Offline
                  hobbnob
                  i have quite a pressing question: will sp3 final and sp3x be able to coexist? because if not then there will be a few issues
                  My WIP Thread:Here
                    CPhillips
                    SP3x will be out as soon as I can finish a few things and add some warnings.
                    In the meantime a few of the new script commands are available even without the events.
                    Create a cone and a sphere. Then set the thruster to:
                    lookAt("sphere");0
                    lookAt is a new script command that forces an object to "point at" another uniquely named object.
                    The ";0" part means that the thruster is off. If you want you could make it ";leftx" or whatever.
                    Note I think I might change lookAt to something else. So it might not work for long. Thats the nature of these experiments.
                      phy
                      lookAt("sphere");0
                      thought you guys might like this
                      two boxes fighting
                      Tableau de comparaison de Staxyn s'agit d'un mะ“ยฉdicament uniquement sur ordonnance.
                        Physicsguy1
                        When i added the batting practice noise script to a machine gun, it wouldn't play the noise until a minute later. That even happened after the simulation stopped. What is wrong?
                          Physicsguy1
                          Nevermind. It was just a mistake
                            Physicsguy1
                            May i request that instead of cutting the sound off when the object is hit during another sound cycle, make them overlap. Almost like a machine gun. OFF TOPIC: I had some more disastrous results when i had built a machine gun. I could only hear white noise when the projectiles collided, so i kept turning up the volume. BOOM!!! after the last shot had collided my eardrums had never seen worse days. Right now i feel pretty stupid...
                              CPhillips
                              The sound is limited to what the built in Sketchup play_sound command can do. At some point I may hook up a real sound API. But not anytime soon.
                                CPhillips
                                Sorry the SP3x version isn't ready yet. I haven't had time to work on it this week. And it looks like I am going to have to fix a few bugs in the Release Candidate first.
                                  CPhillips
                                  Did this in a few hours. It uses the Knight model and animation from Scott Lininger's Prince IO game:
                                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14291&start=0&st=0&sk=t&sd=a
                                  It uses lookAt to point the knight in the direction the joystick is pointed. and the new push command to make him move.
                                  The animation is a trick used in the Knight game. The object really contains all the animations as hidden geometry. I cheated a little bit on the animation playback. ๐Ÿ˜„
