    SP3x. The Plan.
    21 Posts 7 Posters 3.9k Views 7 Watching
    • H Offline
      hobbnob
      lucky sods, cphilli[s deleted the one with on touch and ontick, which is annoying, what is the eta on sp3x?
      My WIP Thread:Here
      • W Offline
        Wacov
        Ah πŸ˜„ we both had it too, but I think we both reinstalled it πŸ˜„ No worries, SP3 X is just a few days away...
        • H Offline
          hobbnob
          yeah in a few days we shall be in a state of pure elation 😍
          My WIP Thread:Here
          • W Offline
            Wacov
            I dunno; I think that cone's watching me...
            • H Offline
              hobbnob
              things are going to be proper advanced with things like that, just imagine: tracking turrets, missiles etc, automatic dogfighting aircraft that jink if hit, imagine the possibilities!!
              My WIP Thread:Here
                Platypus5
                When will the final version of SP3 be released?
                • W Offline
                  Wacov
                  I think technically this is the final version. SP3 X is actually separate, since models made with it probably won't work in SPIV.
                  • H Offline
                    hobbnob
                    i have quite a pressing question: will sp3 final and sp3x be able to coexist? because if not then there will be a few issues
                    My WIP Thread:Here
                      CPhillips
                      SP3x will be out as soon as I can finish a few things and add some warnings.
                      In the meantime a few of the new script commands are available even without the events.
                      Create a cone and a sphere. Then set the thruster to:
                      lookAt("sphere");0
                      lookAt is a new script command that forces an object to "point at" another uniquely named object.
                      The ";0" part means that the thruster is off. If you want you could make it ";leftx" or whatever.
                      Note I think I might change lookAt to something else. So it might not work for long. Thats the nature of these experiments.
                        phy
                        lookAt("sphere");0
                        thought you guys might like this
                        two boxes fighting
                        Tableau de comparaison de Staxyn s'agit d'un mΠ“Β©dicament uniquement sur ordonnance.
                          Physicsguy1
                          When i added the batting practice noise script to a machine gun, it wouldn't play the noise until a minute later. That even happened after the simulation stopped. What is wrong?
                            Physicsguy1
                            Nevermind. It was just a mistake
                              Physicsguy1
                              May i request that instead of cutting the sound off when the object is hit during another sound cycle, make them overlap. Almost like a machine gun. OFF TOPIC: I had some more disastrous results when i had built a machine gun. I could only hear white noise when the projectiles collided, so i kept turning up the volume. BOOM!!! after the last shot had collided my eardrums had never seen worse days. Right now i feel pretty stupid...
                                CPhillips
                                The sound is limited to what the built in Sketchup play_sound command can do. At some point I may hook up a real sound API. But not anytime soon.
                                  CPhillips
                                  Sorry the SP3x version isn't ready yet. I haven't had time to work on it this week. And it looks like I am going to have to fix a few bugs in the Release Candidate first.
                                    CPhillips
                                    Did this in a few hours. It uses the Knight model and animation from Scott Lininger's Prince IO game:
                                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14291&start=0&st=0&sk=t&sd=a
                                    It uses lookAt to point the knight in the direction the joystick is pointed. and the new push command to make him move.
                                    The animation is a trick used in the Knight game. The object really contains all the animations as hidden geometry. I cheated a little bit on the animation playback. πŸ˜„
