    Soft modeling (organic)
    38 Posts 17 Posters 6.6k Views 17 Watching
    • soloS
      What do you consider a medium mesh?
      • H
        hebrides
        My opinion is subjective I will admit based on my modeling behaviour (fever) and content. I also need to be able to convert to solid (in 70% of the cases) which is proving to be possible only with careful model construction.
        Regardless, a medium mesh in my libraries would be about 200K.
        • soloS
          200kb medium? wow! that's low in my book, so what do you consider low and do you have any samples of medium and low components that look half decent?
          rombout, here is a fast time lapse of a curtain blowing in the wind (a real fast and nasty one, but for the sake of understanding my process only)
          http://img167.imageshack.us/img167/3483/curtainu.gif
          • H
            hebrides
            Less than 100k. I'm not going to try and qualify my advise. You know yourself this is a perpetual problem and balancing act between pre-vis quality and model size. If you have the time to put together packs and you are interested in earning a living then I will leave it to you to create decent low poly models. You have got the visualization down, you are a master. I would turn my attention to building effective low poly packs. If this is something you can achieve, I do believe that this approach would help you gain some momentum.
            If you are running out of ideas then I suggest you try to build some solids with SU. What you will see very quickly is the basic primitive SU tool set is still most efficient. You will be shocked by the messy, hole laden models that the SU power tools produce, i.e. follow-me, push-pull. This is even more pronounced when you rev up these tools with Rubies. What you are faced with is hard work to achieve what I suggest. You would need to set asside the power tools and see exactly what can be built to your standards with the least number of faces and edges in SU.
            • H
              hebrides
              Solo....I hope this gives you some ideas.
              There are many complaints about the speed of SU and its inability to handle large poly counts. In my engine development world which has to remain nameless, the ability to carry heavy models with C++ code is based on the accuracy of the models in the world space. SU is a surface modeler designed for ease of use. It has features that require very complex algorithms, inferencing a good example.
              These algorithms are built to make assumptions about the real world space. The placement of faces and edges in Sketchup cannot be described as accurate. As a result, the algorithms need to be very complex and take up a lot of processing time to make assumptions about how the mesh is connected and where each wire is positioned in the real world. As it is, SU does a better job of this than anyone. That is why it is so easy to use.
              If you have access to engines that can recognize solid as well as surface models (for the purpose of accurate measurement)in the same environment you will find that the solid models are very easy to work with. Their geometry is true. The algorithms don’t need to churn through hundreds of tests on the geo in order to understand its present state and position. The state is a constant, it is accurate.
              On the other hand, if you run an identical model that is not solid, there is a large computing overhead required just to figure out the true shape of the model let along its true position in the world space.
              Before Sketchup can move ahead to heavy models and complex meshes it needs to reduce the complexity of the algorithms required to support complex surface models by becoming more accurate in laying down the mesh in the first place.
              This is a major undertaking as we are finding out in my little part of the modeling world.
              What you can’t see in Sketchup is how inaccurate the mesh really is. It looks perfectly normal. I don’t see any holes in your couch above Solo. On close inspection you will find that it is a mess. It has nothing to do with your modeling. It is a product of the tools. An easier way to explain would be to say you are not seeing all the hidden geometry. You are not seeing the geometry that the C++ algorithms see.
              The (proprietary)engine that I use reveals a lot of secrets about real mesh. For example, I can take two models, both modeled in Sketchup, both look the same and the file size is the same. The mesh looks exactly the same (in Sketchup) as well. One of the models was built using the line tool only. The other with all available native tools in Sketchup. Even though the models are materially the same the model built with the line tool can be read, understood and moved with less than half the computing overhead. It has more accurate and consistent real world coordinates and so it is much easier for the C++ to digest without wild algorithms bordering on AI.
              What you see is not what you are getting. In order to build more efficient models in SU you need to be able to see the mesh as the C++ would.
              • david_hD
                david_h
                I got about 1/2 of that . ..
                • H
                  hebrides
                  Well I am sorry it was a bit painful. I was a few years wondering about this stuff without a clue until I was forced into the solid modeling world. For me/us it is about "what you see is not what you get". Although surface models look great it is what you cannot see that is the problem. It is not an easy subject for me but it has become necessary to understand the differences. As you can understand it is not possible to fix something if you cannot see it. For me the whole exercise has been a revelation in my model building career.
                  • david_hD
                    david_h
                    NOt at all. Im just a dummy when it comes to this stuff.
                    I do model quite a bit of Drapery as per Solo's technique and then when I have to make it different I use Freescale and/or FFD to reshape the same component. Lots of fun!
                    The beauty of this particular design is of course all mine.
                      remus
                      Hebrides, in what way are the meshes inaccurate? I was under the impression every edge was just a vector, and so by joining vectors you made faces. I cant see any inaccuracy in this, although apparently im missing something.
                      • soloS
                        oooh! my head hurts now.
                        feel like I've just taken the red matrix pill and the real hole ridden nasty model behind the SU illusion facade has just been revealed. 😮
                        • W
                          wolfy
                          Solo, I highly enjoyed your plant collection and admire these soft models you are developing, but I look forward even more to your tutorials so I can model my own custom designs. Having that ability would be more valuable to me than purchasing a package of someone else's designs. Plants and trees, on the other hand, are a must!
                          Thanks again for all your great work ☀
                          • H
                            hebrides
                            I guess I tried a little to hard to explain. This discussion started with, what should I offer as a pack. Since you seem like a serious person and capable of creating some very amazing work it would be to my advantage to have you create, as you say "decent looking models" at the seemingly impossible size I suggest.
                            You asked how that would be possible and without giving away the proprietary farm I suggested an approach that might be enlightening.
                            • Find yourself a solid modeler
                            • Create a simple object in Sketchup
                            • Import it into the solid modeler
                            • Try to have it verified by the modeler as being solid
                            It all sounds so obscure. Probably because it hasn't been explored.
                            Remus you would need to see it to believe it as well. I can't answer your question. I wasn't able to explain in the first place or you wouldn't need to ask. It has been my observation that if you build your models using techniques that satisfy solid model verification, they will perform better in Sketchup and in any other model application environment. They are also easier to convert accurately into other model formatts. I suggest this is worth exploring.
                            • daleD
                              dale
                              hebrides, which solid modeling software would you suggest?
                                Hopefully a free one
                                What is the name of it? 😉
                                • H
                                  hebrides
                                  Hopefully a free one that can open a .stl and verify that it is a solid. I have tried this with other common formats including dfx/drw but the conversion from .skp is such a leaky mess it is not easy to repair. The solid modeler will complain forever about non-primitive elements and intersecting geometry, lines not sharing an even number of faces, The solid modelers will list the primitives and let you inspect/repair/delete/ so that if your import is clean enough you need only to satisfy a few complaints and you have a solid. In a way the solid modeler is teaching you how to connect things so that it can interpret easier. It helps point you to the places in your model where sketchups math doesn't fit well in a solid model scenario. So you go back to the original su model and you insect these areas. Your inability to verify your model as solid may turn out to be the tool that you used to create the shape. Although the tool is effecient in SU, it is just not going to be identified easily by the solid engine. So I am suggesting, with some practice, your models will perform better in SU even though there doesn't appear to be any differences from the original visible mesh or the file size. This is the behaviour I am experiencing. I am building most models that go into production to emulate solid now. Everything works better.
                                  Sorry, forgot: There are tools available if you look, that will convert a .skp to a .stl. The guys in the 3d printing business have them. I suggest this is the best intermediary conversion format I have found to experiment this way. I have to leave finding the solid modeler to you. The one I am currently using is not a matter of choice. It just happens to be in use where I work. It is not free
                                  • H
                                    hebrides
                                    I'm sorry...I have not used a free solid modeler so I can't point you to one. But any CAD capable software makes solids. I would expect there are some free ones.
                                      I take it that the problems stems from SU's problems with generating faces that's smaller than 1mm leaving tiny gaps which is very hard to spot by eye and impossible to close unless you scale it up by 100 then down again?
                                        remus
                                        i think its more to do with SUs inability to create watertight meshes, as these are what would be needed or a solid modeller.
                                        Hebrides, surely importing poly objects in to a solid modeller is a very inefficient way of doing things, as your going to have way more faces than you need in your solid modeller.
                                          remus
                                          Surely the time it takes to create anything more complicated than a box with the line tool is huge, though.
                                          Is there really that much of a performance increase to warrant spending hours building the model in the first place?
                                          • H
                                            hebrides
                                            I'm saying SU can create watertight models. I am building them and they are more efficient in SU.
                                            Of course but, doing what? It happens to be the best method I have found for determining how good the SU mesh really is. It is the most efficient way to improve an SU model that is already well made.
                                            • 2 / 2
