    All known scripts
    30 Posts 8 Posters 5.3k Views 8 Watching
    • W Offline
      Wacov
      Whaddya mean, no way to fix it?!? oscillator(50/(-righty+1)) does the trick nicely 😄
      Good walker, shame about the joysticks
        klaufi
        controllable oscillators:
        Math.sin(frame/(10*slider('speed')))/3.0
        just an example, numbers are replacable, also you can add constants, use Math.cos or use keys and so on
          BTM
          I thought It would be possible with a math.sin script! 😄 Thanks!
          ...Now anyone here want to explain how to use math.sin, or math.cos, or any other scripts of that type, so I can customize it?
            CPhillips
            That formula is going to have the same problem as the other ones. Its a little hard to understand, but because it is based on frame and nothing else if you change the slider the oscillating body is going to try to jump around.
            I think to make it work right it is going to require the ability to store values from one frame to the next and a bit more math. The first will be in next release.
            Then I can try to figure out the math. After I will update the oscillator script command to make it work correctly.
            Math.sin is just a trig sine function. You may or may not need it for any given script. It just depends on what you are trying to do.
            • H Offline
              hobbnob
              please someone help me: I don't have any idea how any of these works, so I'm going to ask one simple question: I'm trying to make a dynamic oscillator, one that basicly goes haywire in parameters it has been given. is this possible with any of these scripts?
              My WIP Thread:Here
                CPhillips
                Not with the current version.
                • H Offline
                  hobbnob
                  cheers i guess, thanks for trying
                  My WIP Thread:Here
                    BTM
                    You can get fairly random movement if you type in something like
                    oscillator(60)+oscillator(379)*oscillator(-515)+oscillator(223)*oscillator(725)
                    That's just an example, I don't know exactly how well it would work. The point is, if you type in random numbers, plus other random numbers, at speeds varied by other random numbers, the results will be nothing short of random. Well, almost. After a while it would loop.
                      CPhillips
                      There is also a rand command.
                      This will give a random number from 0.0 to 1.0
                      rand()
                      And this will give a random number from 0 to 100
                      rand(100)
                        Physicsguy1
                        The object seems to prefer a higher value, like 0.9. I haven't seen it go back to the original position yet.
                        • H Offline
                          hobbnob
                          thanks the rand command worked perfectly, and also: BTM your walker is not the firstf i almost uploaded my scarab walking tank as my 150th remember? guess not...
                          My WIP Thread:Here
                            phy
                            Anyone know if you can use the mouse buttons. It is in the virtualkeycodes.rb as rbutton and lbutton and since you can use pretty much all the other keys, I was wondering if you can use the mouse buttons.
                            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                              CPhillips
                              Those values in the key table don't work. I think there is a conflict because Sketchup is using the mouse.
                              • 2 / 2
