Needs help with brick material(Vray for SU)
I've got this brick materail in Vray, I added a bump (bitmap) and then chose the jpeg image. When I check the update preview I can see the result but its when I render, nothing shows up. Can someone either help me solve this problem or give me a simpler way of getting a nice realistic brick material.
Thanks in advance
Can you post screenshots?
Also, how did you apply the brick texture? On to a group/component or the geometry itself? VfSU has problems with the texture mapping when it's applied to groups/components.
Also what version of Vray are you using?
Scott
