    How to transform into faces?
    8 Posts 6 Posters 619 Views 6 Watching
      bouillet
      hi!
      sorry for my bad english, i'm french.
      I have a problem: i imported a plan from Autocad (*.dwg file) in Sketchup
      all the buildings are made of lines, so I can raise its because they are not considered as faces...
      For example: this building cross-shaped, how can I transform it into a face?
      http://img11.imageshack.us/img11/996/screenshotsketchup.th.png
      Thank you very much.
        Simon B
        Bonjour Bouillet:
        Rechercher ici: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/fr_RUBY_Library_Depot.html
        "projet de ligne"
        Pardonner mon mauvais francais
          bubbalove
          You could trace over the edges with the pencil and it should fill in as long as your drafting in AutoCAD is accurate. Or you could use the Make Faces ruby. Just type that in on the search function at the top right of your browser...
          Hope this helps ya...
          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            bouillet
            !! I tested Make Faces and.... 👍 AWESOME!! 👍
            Thanks for all!
              bubbalove
              Glad that helped...
                You could draw a face in the same plane as the lines, then select all and Right-Click->Intersect
                  daarboven
                  Neat trick!!! 👍
                    Il y a aussi un forum français au cas z'où! 😉
