    Solar Hot Water Question
    9 Posts 5 Posters 788 Views 5 Watching
    • F Offline
      fbartels
      I've been looking into solar hot water panels, both for heating water and as a partial solution to home heating. In order to use solar for home heating many more panels are needed than the typical 2 or 3 used for water heating. In the warm months of the year these extra panels would be generating a lot of heated water. Here is my question. Has anyone run across interesting ways to harvest all the extra energy collected over the summer (besides everyone in the family taking really long showers)?
      • W Offline
        watkins
        Dear Fred,
        You might find these sites useful:
        http://www.azsolarcenter.com/technology/pas-1.html
        http://www.homepower.com/article/?file=HP114_pg10_AskTheExperts_4
        Short term storage can be increased by burying an insulated water tank in your back garden and heating the water in that, giving you hot water during the night and on cloudy days. Very long term storage is another matter.
        Regards,
        Bob
          tim
          Sure;
          a) build a swimming pool
          b) heat it with that hot water
          c) invite many hot babes round to use pool
          d) enjoy
          • F Offline
            fbartels
            Bob, thanks for the links. Tim, thanks for the humor.
            I asked the question to the tech folks at Radiantec and they replied with the following. I think if you could somehow use the surplus summer heat to generate electricity you would have a really sweet solution.
            Thank you for your recent visit to our website.  We design the system so that the panels are mounted at an angle that most effectively captures the winter sun that passes lower on the horizon.  During the spring, winter and fall we utilize a high temperature override control.  When the system temperature gets too high this control will turn on one of the radiant pumps and circulate water through a zone even if the thermostat for that zone is satisfied.  With this detail we are storing the extra heat within the envelope of the home.
            During the summer when the sun passes over higher in the sky the panels are not making as much heat.  We hope that much of your domestic hot water can be heated by solar during this time.  If the system temperatures get too high and no domestic hot water is being consumed than another type of safety control is used.  This control is referred to as a Heat Dump Valve.  The Heat Dump Valve is attached to the domestic hot water line and when activated by a high temperature reading it allows some hot water to be drained from the system.  This action allows fresh cold water to flow into the system cooling it enough to allow the panels to once again begin working.
            A newer feature that Radiantec has designed for prevention of over heating during times when extra heat is not desired in the home is referred to as “Garden Root Zone Heating”.  All though this is a manual valve operation it is a great way to rid the system of excess temperatures.  The idea is to bury tubing under a garden area.  A valve can be opened to allow heated solar fluid to circulate through the garden zone which could very well extend your heating system in the later fall months.
            • pbacotP Offline
              Do you think they mean "extend your growing season"?
              My understanding is that the solar angle is crucial for max. efficiency of these systems and, by their nature, they would be difficult to make tracking or adjustable, as photovoltaic panels sometimes are.
              You may be onto an idea. Maybe someone with some background in refrigeration can explain how a refrigerator runs on a gas flame (not me!), but that's an example of heat being made to do something else. An engineer could tell you if there is enough thermal energy of the right sort to make any such an effort worthwhile.
              • jim smithJ Offline
                jim smith
                Here is a link to a Wikipedia article on absorption refrigeration, rather than compression refrigeration. They do mention one possible heat source as "solar" in the article. I have seen some propane operated absorption refrigerators that have a backup electrical resistance heater to pick up the slack if the propane runs out before a tank recharge. However, I have not seen a production model solar fridge.
                Absorption refrigerator - Wikipedia
                (en.wikipedia.org)
                "Out of clutter find simplicity,
                from discord find harmony,
                In the middle of difficulty lies opportunity"
                Albert Einstein
                • F Offline
                  fbartels
                  pbacot... I do think they meant "growing season".
                  Jim, Thanks for the link to Wikipedia on absorption refrigeration. I found this link to a short TED talk off that page.
                  TED | 404: Not Found
                  (www.ted.com)
                  I couldn't find much more about this but it certainly sounds like it would be a perfect complement to solar heating.
                  Fred
                  • W Offline
                    watkins
                    Dear Fred,
                    Another interesting link
                    302 Found
                    (www.sciam.com)
                    Regards,
                    Bob
                    • F Offline
                      fbartels
                      The Steinway piano company is just completing the installation of the world's largest solar cooling system using absorption coolers.
                      (www.greenbuildingadvisor.com)
