    Groups/components
    12 Posts 4 Posters 807 Views 4 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Make a cube, select it (all of it), then right click it and select "make component". Now windows > component and select the component, then add it to the model. When you "edit component", the changes will be reflected in all of components.
      • X Offline
        xrok1
        thankyou, but i think you missunderstand me.
        if i have 10 cubes in my scene, each one is copy of the first, now i want 10 cube components to replace the ones i have. ๐Ÿ˜•
        do you understand what i'm trying?
        PS i'm just hoping but i realize it probably won't work. ๐Ÿ˜ข
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
        • X Offline
          xrok1
          @honoluludesktop said:
          unless what you are trying to do change the individual cubes in the model into a single component after the fact.
          yes, but i want the individual cubes to be individual components not all one component. ๐Ÿ˜„
            honoluludesktop
            Sorry, must be too early in the morning here, I didn't get it ๐Ÿ™‚ Is what you are trying to do, is to change the behavior of the individual cubes in the model into that of a component after the fact. Wow, are all the cubes the same? That would be a neat trick.
              honoluludesktop
              Try this, I made it work in one instance. Select one cube and make it into <Component#1>, or what ever the current name is. Then select another cube, and when you are prompted for a component name, use <Component#1>. The system prompts you for approval, acknowledge, and the first selection is converted to the second, both named <Component#1>. I think.
              • X Offline
                xrok1
                yes that worked, thanks. now i wish there was a way to do it for multiple instances at once.
                  If only I'd known. ๐Ÿ˜‰
                  Apply To will do what you want. Make the first cube a component. If it's a group already, just right click on it and choose Make Component. Make the rest of the cubes components in the same way. Then, right click on the first and choose Component Definitions>Get Definition. Select all of the others, right click and choose Component Definitions>Apply Definition. Presto!
                  I almost never make groups when I am drawing. Even if the thing I'm drawing is the only one in the model, I make it a component. Invariably I'll want it to be a component at some point and it's easier to make it a component from the get go.
                  • X Offline
                    xrok1
                    SHUT UP! ๐Ÿ˜ฎ
                    thats it i'm just calling you next time Dave. ๐Ÿ˜†
                    whats your number? ๐Ÿ˜›
                    PS maybe you can riddle me this: if i group something the make it a component=no dialog, if i triple click geom. then make a component, dialog?
                    One other thing is it better to right click a component and save as OR... drag it from in model components to component library?
                      ๐Ÿคฃ
                      Just throw up the signal on the clouds. I'll see it.
                      re: no dialog box. Maybe it's punishment for not making a component in the first place. ๐Ÿ˜† You can make some adjustments in the Entity Info box but if you want to assign other attributes such as cutting openings or Face Me, you'll need to explode the group and then Make it a component.
                      As to which is better? I guess I would do the click and drag thing. Probably fewer key strokes. Epecially if you have a number of components to save from the model.
                      • X Offline
                        xrok1
                        thanks, i'm glad i could entertain you with my struggles. ๐Ÿคฃ
                          @dave r said:
                          ...You can make some adjustments in the Entity Info box but if you want to assign other attributes such as cutting openings or Face Me, you'll need to explode the group and then Make it a component...
                          Or in the component browser > Right click on a component "In model" > Go to Properties. This willopen the component dialog missing when turning a group into a component.
