    Soft modeling (organic)
    38 Posts 17 Posters 5.0k Views 17 Watching
    • soloS Offline
      Hey guys, I'm fiddling with an idea, like my Sketchup garden pack I am wondering about creating a 'soft model' pack.
      This time I need to do more market research as my first pack was not as popular as I'd hoped it would be 😕
      I know there are many 3D models out there that are free so my question would be, what if there was a pack with stuff that are not
      so easily available and one that has been made in SU especially optimised for use in SU?
      I'm talking about plush couches, assorted curtains, undulating bedding, pillows, crumpled rugs, dimpled chairs, etc. Medium poly models
      that can be used for renders and look pretty realistic.
      The reason I ask is that such modeling takes a long time and much effort so before embarking of such an endeavor I need to know if there indeed is a need for these models and if there are any specifics that y'all may need or if included would be enticing enough for you to consider a 'Softpack'.
      Here are a few examples:
      http://img24.imageshack.us/img24/3015/1solosbeds.png
      http://img19.imageshack.us/img19/982/1solocurtain4.png
      http://img18.imageshack.us/img18/9741/1solocouch1.png
      http://img15.imageshack.us/img15/5166/1leathercouch2.png
        mateo soletic
        Medium poly models that can be used for renders and look pretty realistic.
        Pete,
        I think this is a good idea worth exploiting further. These are some of the weak spots that can spoil even the best render. It would be good to be able to complete the whole modeling and set up process in SketchUp itself.
        [Concept Illustrations](http://concept-illustrations.com/)
          dylan
          It seems a good idea to me.
          Add in some curtains flowing in the wind which can be shown blowing outwards! I think you did this in one of your recent renders.
          http://dmdarchitecture.co.uk/
          • soloS Offline
            Good idea, I will add about 3 variations.
            http://img16.imageshack.us/img16/1414/1blowcurtain1.png
              steelers05
              Great models man. Im still waiting on that tutorial of how your mapping some of these textures. They look amazing. Before shots of these, with the un-subdivided/smoothed geometries would be very helpful too, for n-b's at organic modeling like me...if you dont mind? Keep up the great work.
                l.frisken
                hey solo, just wondering how you got such a good texture map on that curtain? did you project it? and in what way did you project it? Thanks
                  kwistenbiebel
                  Hi Pete,
                  I will be honest.
                  The models you make are great and they show great skill, but there are a lot of beds, sofas and furniture out there already (3DWarehouse, Formfonts,Archive3D, etc...)
                  I am still convinced that trees a la Xfrog , but 10 times less polygons than that collection, would make a great commercial package.
                  It is very tricky to make them look real, but if you succeed and keep them (relatively small ,5Mb or so?), you have a good commercial product imo.
                  • E Offline
                    Ecuadorian
                    @kwistenbiebel said:
                    I am still convinced that trees a la Xfrog, but 10 times less polygons than that collection, would make a great commercial package.
                    +1
                    My PC thinks it's a 286 when I load even just 3 Xfrog trees.
                    -Miguel Lescano
                    • soloS Offline
                      Thanks guys, I agree there is enough of this kinda stuff available.
                      I will have another look at the tree thing, 5mb sounds pretty doable, but I will need to try a few ideas, I may need to use .png's for the foliage however, which gets complicated with apps like Vray that make using png's so awkward.
                      If I was to create these trees would making a basic low polygon shape named say 'Birch-proxy' accompany the high poly 'Birch' so that one can do the instancing in SU?
                        steelers05
                        Solo, check out these trees ande. made. (http://asgvis.com/index.php?option=com_smf&Itemid=90&topic=5508.15) They honestly are the best trees I have delt with. They arent as cumbersome as xfrog (which end up just crashing my comp. anyways), and they look just as good in my opinion. But they use alpha masking, and they work fairly well. I think the trick with v-ray is to use the same file type for the actuall texture and for the transparency mask, because I have tried using a jpeg for the texture and png for alpha, and got bad results. So I usually take the png. file and make my texture and alpha in PS and then apply them to the component, foilage. I have fairly strong computer I was using but was able to get about 15 trees in my scene and I could have probably fit a fair amount more. They really were the best solution I have seen for SU. So I would try to encourage this technique with the model and png. texture included, but it ultimately is up to the artist. Either way I know you will give us something great. Keep an eye on the gallery, I am going to try to get the renderings up that I did with these trees sometime soon to give you a better idea of how they turn out.
                          Using PNG for foliage is ok. It's not a big deal to add an alpha channel. But it's nice of it isn't built up of too many different materials as currently V-Ray material won't import with components so the process of adding the alpha channel have to be done each time.
                          An XFrog trees often comes in with between 80K-120K faces, which quickly kills a model. But it'd be very interesting with <10-20K trees that still look good.
                          XFrog usually have each leaf, or maybe 3-4 leaves in a png, but it's still allot. A lib with trees that's lighter, but still appear detailed, with volume would be very interesting.
                          • romboutR Offline
                            rombout
                            Hi Solo how do you map these meshes like that... its not done in SU i think... im i correct.. id like to learn how to map organic shapes
                            • soloS Offline
                              rombout, It's 100% Sketchup, created and textured in SU.
                              I do not have a tutorial on hand but keep an eye on the main site where the new tutorials are, I am sure there will be a few organic modeling tutorials coming soon.
                                Clarencecat
                                I think this will be an excellent package - not everyone is aware how good these soft furnishings can look,
                                would certainly add realism to interior shots.
                                I'm always amazed by your modelling
                                • soloS Offline
                                  I probably will continue with this package, I have 17 models so far that are medium poly at about 600-800kb.
                                  Here is another couch.
                                  http://img256.imageshack.us/img256/4781/velvetcouch.jpg
                                  and a quick time lapse of a set of cusions being made.
                                  http://img152.imageshack.us/img152/8766/cusion.gif
                                  • H Offline
                                    hebrides
                                    Solo, you are a great talent and I have learned much from you. Thanks.
                                    The problem I have with most packs is there size.
                                    I don't consider that to be a medium mesh in SU. I really am tired of hiding these objects in another layer until it's time to shoot....using proxy's, splitting symmetricals, etc...etc. Too many hoops for me. I like to be able to see as much in context as I can while modeling without spending hours preparing them.
                                    If you could produce a set of useful objects that are light, I believe they would sell.
                                    • soloS Offline
                                      What do you consider a medium mesh?
                                      • H Offline
                                        hebrides
                                        My opinion is subjective I will admit based on my modeling behaviour (fever) and content. I also need to be able to convert to solid (in 70% of the cases) which is proving to be possible only with careful model construction.
                                        Regardless, a medium mesh in my libraries would be about 200K.
                                        • soloS Offline
                                          200kb medium? wow! that's low in my book, so what do you consider low and do you have any samples of medium and low components that look half decent?
                                          rombout, here is a fast time lapse of a curtain blowing in the wind (a real fast and nasty one, but for the sake of understanding my process only)
                                          http://img167.imageshack.us/img167/3483/curtainu.gif
                                          • H Offline
                                            hebrides
                                            Less than 100k. I'm not going to try and qualify my advise. You know yourself this is a perpetual problem and balancing act between pre-vis quality and model size. If you have the time to put together packs and you are interested in earning a living then I will leave it to you to create decent low poly models. You have got the visualization down, you are a master. I would turn my attention to building effective low poly packs. If this is something you can achieve, I do believe that this approach would help you gain some momentum.
                                            If you are running out of ideas then I suggest you try to build some solids with SU. What you will see very quickly is the basic primitive SU tool set is still most efficient. You will be shocked by the messy, hole laden models that the SU power tools produce, i.e. follow-me, push-pull. This is even more pronounced when you rev up these tools with Rubies. What you are faced with is hard work to achieve what I suggest. You would need to set asside the power tools and see exactly what can be built to your standards with the least number of faces and edges in SU.
                                            • 2 / 2
