    SP3 Alpha 2 bugs
    8 Posts 4 Posters 925 Views 4 Watching
      BTM
      1. the first bug I've noticed, that I also noticed in SP2, is a bug with frozen objects.
        Sometimes, when they come in contact with a normal object, instead of unfreezing, they freeze back up when contact is lost.
        freeze bug.skp
        In this example, there are 16 cubes with thrusters, and a cylinder on a gyro. move the cylinder into the cubes, and you will see them move, the stop when contact is lost. Then, click on a cube; notice how that unfreezes it properly.
        BTM
        1. The second bug I noticed, again, also in SP2 and mentioned before, is that when multiple objects are connected to a controlled joint, only one of the objects will be controllable.
          cont.joint.bug.skp
          Use the arrow keys or right joystick to see in the example.
          CPhillips
            [attachment=0:31pmss6o]<!-- ia0 -->freeze bug.skp<!-- ia0 -->[/attachment:31pmss6o]
          Wow. never saw that before. It might be a bug in the physics engine. Ill look into it.
            CPhillips
              [attachment=0:149jnx07]<!-- ia0 -->cont.joint.bug.skp<!-- ia0 -->[/attachment:149jnx07]
            I keep forgetting about that problem. I'll see if I can fix it. But probably not before the next release.
            Thanks for the great bug reports BTM!
              phy
              the gear gear ratio doesn't work quite right. I put the ratio to 10 and the wheels just spin (see example) after you touch them.
              geargear bug
              Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                phy
                it does funny things with the worm gear too at a ratio of ten, is this a bug or isn't it. when you click on the wheel everything just disappears
                bug i think.skp
                  CPhillips
                  The physics engine has trouble with high numbers in the gear ratio. Not really sure why.
                  You can connect the joints the other way around and then use a ratio of 0.10 to do the same thing as a 10 ratio. I think.
                  • W Offline
                    Wacov
                    Bug #1 seems very similar to an old one in sp2; that was fixed. In this model, it is fixed if you turn off the thruster setting. I've never found #2 to be an issue.
