    [Plugin] SImple wood working Tools
    25 Posts 14 Posters 32.1k Views 14 Watching
    • Chris FullmerC Offline
      Very cool, thanks! Would you mind editing your initial post title to start be "[Plugin]SImple wood working Tools" (add the [Plugin] tag). Just helps keep the forum easier to search πŸ˜„ Thanks for the scripts,
        remus
        Edited the title, hope you dont mind.
        Thanks for the plugins πŸ‘ always cool to have a few more to add to the collection.
        • X Offline
          xrok1
          it would be great if you'd show some pictures of your tools in action, so we could know (visually) what they do before we decide its worth the fight with our toolbars.
            dammerel
            Great script Joel
            just a question with the drill board, how to you position the hole to be drilled. i tried to select a point but i keep getting invalid point
            Andrew
              Joel,
              Thanks for this.
              I posted this question in the Woodworking forum where you first posted these but I''ll ask it here, too. It concerns the Dado tool.
              "I select the component in which I want the dado. The prompts at the bottom are to click the FROM edge and then the To edge. I would expect the dado would be plowed from the first edge to the second but instead, I get a dado running at 90Β° from the edges selected. I'm also not clear about the "Over" option in the dialog box. Any clarification would be appreciated. Thank you."
                jhoutman
                I tried to post a small word document showing the dialog boxes
                etc. I guess I don't understand how to do that.
                Drill tool needs a point already on the component face.
                Perhaps set by Tape Measure tool.
                The Dado tool "from/to" edges are not the ends. They define
                how you want to place the dado. The from edge and to edge define
                the plane and how your dimensions to the dado are placed. Hence a dimension
                of 1 inch is from the from edge in the direction of the to edge. What
                you are dimensioning to is one of three possibilities To (the nearest edge)
                Center (the center) or Over (to the furthest edge). That is kind of
                an old convention in carpentry.
                Thanks Joel
                  Sawduster
                  Hey, I like those. You can even use the dado tool to make tenons quite quickly. Thanks.
                  May all your dimensions be the sum of their total.
                  Jerry
                  http://www.sawdustersplace.com
                    akigrimm
                    I've tried to translate this simple component. A simple component to draw carcasses with. Maybe you could use it. And you can use it in a report ...
                    • kenK Offline
                      ken
                      Joel
                      Well thank you for the great plugin. I know those who cannot write these plugins never seem to be satisfied. So could this plugin be made to work on groups as well as components?
                      Again thanks
                      Ken
                        brandy20
                        Joel you did a very nice set of tools. I like them!
                        Any chance to have the same in the metric version for the european guys? 😎
                          jhoutman
                          One could in principal make them work on groups rather than components, although, the way I work a "board" (ie piece of wood) is a component. Hence, I work on components.
                          On Metric. It would be simple to make a metric version. Anyone could do it. One could load in the *.rb's and where ever you see .inch on a variable then change that to .mm. You could change a default .75inch to 19mm for examples. The .inch appears in two ways in these scripts 1) as an extension for declared variables (depth.inch change to depth.mm) or 2) as default values for the input box. Make them whatever you want.
                          Thanks for the feed back.
                          Joel
                            Jim
                            It would be simple to make a version that used the user's default units, too. Just use .to_l to convert the dialog values to Sketchup::Lengths.
                              brandy20
                              Joel
                              Well, I can see what you mean now. Thanks.
                                RalphB
                                OK, I'm a newbie but I cannot get your plugin to be recognized by Sketchup 7. I placed the file into the Plugins folder like I did with cutlist, re-started Sketchup, and yet nothing appears in the list I get when I click on Plugins.
                                  Ralph, this plugin doesn't appear in the Plugins menu. It appears as several entries in the Draw menu.
                                    RalphB
                                    Yep, that's officially a "Duhh" I did find it, thanks. It would be nice if the description of a tool such as this told one where it would appear once installed.....
                                      Ralph, if you open the file in NotePad or another text editor, you can read where it will show up. It's typically in the last few lines of the script.
                                      • H Offline
                                        heaker89
                                        hi im use skechtup 8 and can't see where this plugin menu
                                          See this link: http://sketchucation.com/forums/viewtopic.php?f=323&t=17076&p=452505#p138227
                                            tashnag
                                            Hello All,
                                            I got the Plug in and am having a problem with the dado tool. For some reason it works properly from some sides, and not from other sides.
                                            I may have a hard time describing it will but here it goes.
                                            I have a 3/4 (RED AXIS) x 25 (GREEN AXIS) x 27 3/4 (BLUE AXIS)
                                            When I select the FROM edge as the 27 3/4 high edge that's furthest from the Red Green and Blue, the TO edge behind the 27 3/4 high edge on the same plane on the red but still away from the blue and green, the dado window pops up, I enter 1" in the TO distance, TO edge, Width 3/4, Depth 1/4 and it works just great.
                                            When I select the FROM and TO to be the opposite edges it does something really funky.
                                            It doesn't get set in an inch from the outside edge like I want it to (I'm assuming how it should work, as it works on the opposite side) but it makes a rabbet 1 3/4" wide. If I try a dado again after that, it works properly again.
                                            its just from certain edges, it doesn't inset the Dado, but makes a rabbet that uses the TO distance, and the Width to determine the width of the rabbet.
                                            please help me find out whats wrong.
