    [Plugin] SImple wood working Tools
    25 Posts 14 Posters 32.6k Views 14 Watching
    • B
      brandy20
      Joel you did a very nice set of tools. I like them!
      Any chance to have the same in the metric version for the european guys? 😎
        jhoutman
        One could in principal make them work on groups rather than components, although, the way I work a "board" (ie piece of wood) is a component. Hence, I work on components.
        On Metric. It would be simple to make a metric version. Anyone could do it. One could load in the *.rb's and where ever you see .inch on a variable then change that to .mm. You could change a default .75inch to 19mm for examples. The .inch appears in two ways in these scripts 1) as an extension for declared variables (depth.inch change to depth.mm) or 2) as default values for the input box. Make them whatever you want.
        Thanks for the feed back.
        Joel
          Jim
          It would be simple to make a version that used the user's default units, too. Just use .to_l to convert the dialog values to Sketchup::Lengths.
          • B
            brandy20
            Joel
            Well, I can see what you mean now. Thanks.
              RalphB
              OK, I'm a newbie but I cannot get your plugin to be recognized by Sketchup 7. I placed the file into the Plugins folder like I did with cutlist, re-started Sketchup, and yet nothing appears in the list I get when I click on Plugins.
                Ralph, this plugin doesn't appear in the Plugins menu. It appears as several entries in the Draw menu.
                  RalphB
                  Yep, that's officially a "Duhh" I did find it, thanks. It would be nice if the description of a tool such as this told one where it would appear once installed.....
                    Ralph, if you open the file in NotePad or another text editor, you can read where it will show up. It's typically in the last few lines of the script.
                    • H
                      heaker89
                      hi im use skechtup 8 and can't see where this plugin menu
                        See this link: http://sketchucation.com/forums/viewtopic.php?f=323&t=17076&p=452505#p138227
                        • T
                          tashnag
                          Hello All,
                          I got the Plug in and am having a problem with the dado tool. For some reason it works properly from some sides, and not from other sides.
                          I may have a hard time describing it will but here it goes.
                          I have a 3/4 (RED AXIS) x 25 (GREEN AXIS) x 27 3/4 (BLUE AXIS)
                          When I select the FROM edge as the 27 3/4 high edge that's furthest from the Red Green and Blue, the TO edge behind the 27 3/4 high edge on the same plane on the red but still away from the blue and green, the dado window pops up, I enter 1" in the TO distance, TO edge, Width 3/4, Depth 1/4 and it works just great.
                          When I select the FROM and TO to be the opposite edges it does something really funky.
                          It doesn't get set in an inch from the outside edge like I want it to (I'm assuming how it should work, as it works on the opposite side) but it makes a rabbet 1 3/4" wide. If I try a dado again after that, it works properly again.
                          its just from certain edges, it doesn't inset the Dado, but makes a rabbet that uses the TO distance, and the Width to determine the width of the rabbet.
                          please help me find out whats wrong.
                          • T
                            tashnag
                            I found the updated version, and the draw dado now works properly, but the create board wont do anything at all. Any ideas?
                              Maybe the author will chime in but I expect he'll want to know if you're getting any errors in the Ruby console when you try to run it or when you start SketchUp.
                              • T
                                tashnag
                                No errors, with the new version, I can go to the draw menu, select create board, enter the info, and click ok, then nothing... Same if I try to save default. Looks like resize board is having the same issue of not doing anything.
                                • 2 / 2
