    Invitation to the SketchUcation collection
    155 Posts 26 Posters 239.5k Views 26 Watching
    • B
      brandy20
      Dave, I understand your explanation, you talked about your technique in the cabinet project on th FWW blog. So it should be a quick job. I'll try it soon.
      • B
        brandy20
        sorry guys, but I really can't get it! I can rotate the axex but I spent the entire evening in trying to rotate the texture!
        This is what I do:
        I choose the material, I apply it to the component and when I right click the mouse pointed on the texured face of the component I can't find the option Texture-rotate. Where am I wrong?
        This is what I see
          The problem is that you applied the material to the component's "wrapper". That's my term. When you apply the material, open the component for editing, first. Then apply the material to the faces. Select one face that needs to have the material orientation edited, right click and you'll find Texture in the menu.
          See if that helps.
          Dave
          • B
            brandy20
            thanks Dave, tomorrow morning (it's late now here) I'll try to fix the problem. I'll give you the feedback.
            • B
              brandy20
              Mission accomplished!
                Good work! πŸ˜‰
                • GaieusG
                  To elaborate Dave's advice; you can only position a texture/material on a single face. "Not single faces" are (and the "Texture item thus doesn't even appear in the context menu):
                  [list:32expikr][:32expikr]groups/components - like in your case. Dave explained how to solve this.[/β“‚32expikr]
                  [*:32expikr]curved/smoothed surfaces - let them be "really" curved or even just coplanar with a softened, dividing edge (in fact, these edges should be deleted instead of being dealt with like below). With curved/smoothed surfaces however you can do the following
                  • Go to View > Hidden geometry; this will reveal the "facets" building up a curved surface
                  • these facets can be manipulated like single faces - i.e. in this case you can position a texture on one
                  • Now select the Paint bucket tool and pres the Alt key > the tool will turn into an eyedropper/sampler tool
                  • sample the positioned material on the above "one" face
                  • Turn off hidden geometry (again; uncheck it in the View menu)
                  • Paint the whole, curved/smoothed surface with the positioned > sampled material.[/listβ­•32expikr]Sounds to be a lot more complicated and longer than doing it with a little routine...
                  • B
                    brandy20
                    Good shot Gaeius! πŸ‘ I normally use the projection mode to texture curved surfaces and I'm going to try your method.
                    • GaieusG
                      Projection is fast and handy but when the curve goes round too much, it is distorted on the sides. Or actually it is always distorted just in these cases it is too apparent.
                      With positioning however, though it may look "nicer", it is a bit tiresome.
                      • B
                        brandy20
                        Actually I noticed that in a curved leg I made
                          Nice bed Keith.
                          Funny thing, though. The table looks like the bed. πŸ˜‰
                          • K
                            ktkoh
                            Here are 2 new models that may meet the requirements for the collection. One is extra long twin bed made as a captians bed with drawers below the bed. The other is a twin pedestal dining room table.
                            Keith
                            http://sketchup.google.com/3dwarehouse/details?mid=f21822974c8c492085c5f690e9252fc5
                            http://sketchup.google.com/3dwarehouse/details?mid=615b800fb332525385c5f690e9252fc5
                            Edited link to Table
                            • E
                              ericschimel
                              I just posted this model in another thread, but I think its appropriate here.... Its a dynamic, reconfigurable door. I use it all the time for my woodworking plans...
                              Error 404 (Not Found)!!1
                              (sketchup.google.com)
                              -Eric
                              http://plugin.sketchthis.net
                              Sketchup Kitchen Design Plugin
                              Custom Models
                                mics_54
                                Thanks Eric
                                • C
                                  CactusMatt
                                  This is the Heirloom Hope Chest orginally publised by Wood Magazine in Issue 142 (june/July 2002). I built this chest as a Christmas present to my wife in 2008.
                                  From the original plans from Wood:
                                  http://www.the-fam.us/images/Blanket chest from Wood Magazine.jpg
                                  From my model:
                                  http://www.the-fam.us/images/bct.jpg
                                    mics_54
                                    Excellent!
                                    • E
                                      ericschimel
                                      Nice model! I really like it.
                                      Did you use LayOut, or the CutList plugin to figure out how to build it?
                                      -Eric
                                      Custom Models
                                      • C
                                        CactusMatt
                                        [list:3i32cga8][:3i32cga8]groups/components - like in your case. Dave explained how to solve this.[/β“‚3i32cga8]
                                        [*:3i32cga8]curved/smoothed surfaces - let them be "really" curved or even just coplanar with a softened, dividing edge (in fact, these edges should be deleted instead of being dealt with like below). With curved/smoothed surfaces however you can do the following
                                        • Paint the whole, curved/smoothed surface with the positioned > sampled material.[/listβ­•3i32cga8]Sounds to be a lot more complicated and longer than doing it with a little routine...
                                        Thanks for this Gaieus!
                                        I cannot tell you the frustration I've had when trying to tweak some textures on certain surfaces that 'appeared' flat. The "Texture" part of the right-click menu just did not show up (as in the post above). All of these problem-surfaces (it turns out) had some kind of rounded edge-treatment applied (using follow-me). Using your advice, I was able to go back into several of my models and turn-on hidden geometry. Voila! -- I was able to isolate my flat-surfaces ad scale my textures the way I wanted.
                                        • L
                                          Laxian Key
                                          My first complex model in SketchUp. This is my interpretation of Christian Becksvoort's Shaker Collector Cabinet.
                                          • L
                                            Laxian Key
                                            I'm new to SketchUp and there is still a lot I have to learn. I had already finished the knobs before I saw Tim Killen's video about Shaker Knobs on another blog.
                                            I had seen this cabinet in a couple of different publications and I wanted to get the proportions and approximate measurements in case my woodworking skills take a quantum leap...
                                            • 5 / 8
