    New Rendering Contest
    extensions
    23 Posts 9 Posters 6.8k Views 9 Watching
    • N Offline
      notareal
      @al hart said:
      The easiest way is to uninstall it and reinstall it again. When you installed it, it asked for a SU version.
      It is interesting to learn that some people are sticking with SU 6. It means we will have to be careful not to make incompatible. for instance, we supply some components for light bulbs. We have to be careful to keep them at SU 6 level.
      Have to say I am one of those. At the moment I just did not find any reason to upgrade to 7 Pro. SU 6 Pro does give me all the pro features I do need (exports). I do use SU 7 free, time to time.
        Sir
        i get this message when trying to dl the trial
        HForm.com Form Handler
        The form could not be handled. The following error occured:
        The form number or name is invalid !
        is this my problem?
        • Al HartA Offline
          Al Hart
          Fill out the download form one more time for me to see if it works. If it fails again I will send you a lonk to the download page.
          Al Hart
          IRender nXt from Render Plus
          • H Offline
            hebrides
            Thanks Al. I gave it a try. It set up ok and rendered a few small objects quite well. I then tried a few warehouse models but anything but the smallest scene just stops at the collecting faces stage. I am using SU7. I have a dual core with 2 gig, 2ghz processors, 256 meg video.
            • Al HartA Offline
              Al Hart
              Send us the name or link of a 3D Warehouse file which fails and we will try it here.
              For larger models, you need to use our Batch Rendering Mode which can render models which are 2 to 5 times as large. (We can process larger models in a separate batch process when we do not have to share the available memory per process with SketchUp)
              Al Hart
              • H Offline
                hebrides
                Before I waste any of your time I will build a reasonable sized model with detail and see how it goes. I will for sure try the batch mode as well. Thanks Al!
                • soloS Offline
                  Al
                  This is great news, I have a model that's too big for Indigo and Podium to render,so far only Vray has been able to process it, I will give it a go with NXT batch, if it works as I hope I may be able to do the animation with it that I need without having to try get it into Max.
                  I must say the render with edges is a fantastic addition, glad it's a feature and the HDRI has been made simple.
                  One thing that I have noticed is the UI is very simple yet has many bells and whistles, it does as it says and the renders are very fast.
                  So far I'm very impressed with the new version. 👍
                    richcat
                    Glad to see your enjoying it as much as me 👍 so far.
                    It will interesting to see how you get on. I believe there is also a 64 bit batch rendering version that I believe Al colud give you access to if the 32 doesn't work. They have been waiting for people to push the size limit.
                    Lets hope with this competition others give it go and find out it virtues. Quick and simple, but with access to additional more complex features if you need them.
                    • E Offline
                      Ecuadorian
                      Can people outside the U.S. enter the contest?
                      -Miguel Lescano
                      • Al HartA Offline
                        Al Hart
                        Yes. The prizes will be awarded as Amazon.com gift cards (or software credits at Render Plus)
                        Are you able to access and use Amazon.com?
                        Al Hart
                        • E Offline
                          Ecuadorian
                          Sure, I buy a lot of my stuff from Amazon.com, including electronics. The only thing they don't sell to foreigners is mp3s & video downloads. Glad to know you're accepting people from around the world. I'll give this a try.
                          -Miguel Lescano
                          • N Offline
                            Nunja Business
                            It sure would be nice to have the 64-bit version available.
                            • Al HartA Offline
                              Al Hart
                              A '64-bit' version will not be faster, except for very large models.
                              Compiling an application for 64-bits makes it run slightly slower, because all the address references in the programs are twice as long (64 bits instead of 32 bits), so the program itself is larger.
                              The new version of IRender nXt which we will release Monday can process models which are 2 to 3 times large. (We found a way to process larger models).
                              Al Hart
                              • Al HartA Offline
                                Al Hart
                                Do I have to purchase IRender to enter the contest?
                                No, we are providing a free, 30-day version for all contest participants (See: Contest ) .
                                Also, a you can choose a free copy of IRender nXt as your prize if your entry is selected as the best. ☀
                                Al Hart
                                • Al HartA Offline
                                  Al Hart
                                  There are just a few days left in the Rendering Contest.
                                  We have received some great entries, and I know some of you are waiting until the last minute to get yours ready.
                                  Additional Prize
                                  We have decided to add one more (potential) prize as follows:
                                  If both of the top two winners already own IRender nXt, then we are going to award a copy of IRender nXt to the top finisher who does not already own a copy of the product. That way the best rendering by a contestant who does not own the software will get a free copy of the software.
                                  See: Contest for more information on the rendering contest.
                                  Also, we will automatically enter any images which are uploaded directly to the IRender nXt Image Gallery.
                                  Extension to Deadline
                                  We are not going to extend the contest beyond April 2nd. However, if you need just a little more time, you may request a 72 hour extension to complete your rendering. Send an email to contest@renderplus.com telling us that you need just a little more time, and we give you an additional 72 hours to get you entries completed.
                                  Resolution
                                  All images will be judged at 800 x 600 resolution, however you may submit larger resolutions if desired. (The larger resolution image may be helpful when the images are added to the Image Gallery)
                                  Submit contest entries to contest@renderplus.com
                                  Al Hart
                                  • Al HartA Offline
                                    Al Hart
                                    Contest Ending
                                    The rendering contest is over, (except for a couple of people who requested an extension until tomorrow). We will carefully evaluate the entries and choose about 10 finalists, whom we will announce next week.
                                    http://3.bp.blogspot.com/_6fYuJ9zvtyg/SdfSiPLR4hI/AAAAAAAAADI/PjNbyHQ2aBk/s320/contest-entries.jpg
                                    Al Hart
                                    • Al HartA Offline
                                      Al Hart
                                      If you have submitted an entry for the rendering contest, you should check this page:
                                      Contest entries
                                      http://wiki.renderplus.com/?title=IRender_nXt_Rendering_Contest#Contest_Entries
                                      To make sure we have it. If we don't have it, send it again to contest@renderplus.com
                                      I will respond to the email, so if you don't get a response after a reasonable period of time, add a post here so we can contact you.
                                      Al Hart
                                      • Al HartA Offline
                                        Al Hart
                                        We have selected the finalists in the IRender nXt Rendering Contest. Thanks to all who participated. Take a look at: Rendering Contest
                                        Now we just need to determine the 3 winners from the 12 finalists.
                                        Also, we are letting the SketchUp Community be one of the judges. Cast your vote HERE.
                                        Al Hart
