    [Request] Transformation rotation for animation help
    15 Posts 4 Posters 4.4k Views 4 Watching
    • T
      tomasz
      @chrisglasier said:
      My idea is to kind of sneak up on namesets from the rear, as opposed to previous full frontal assault!
      ๐Ÿ˜„ ๐Ÿ‘
        Jim
        @chrisglasier said:
        Can anyone help me to translate the x-, y- and zaxis results to degrees for each axis?
        Vector3d.angle_between will get you part of the way there.
        angle = t.zaxis.angle_between(Z_AXIS).degrees
        However, angle_between always gives a result between 0 and 180 (or more accurately between zero and ฯ€).
          What..?! All you need to do to convert radians to degrees is appending .degrees? ๐Ÿ˜ฎ doh! ๐Ÿ˜ณ
            Jim
            Heh, see the Numeric documentation for the SketchUp-specific additions.
              Meh,... I've seen that page, taking note of the unit conversion, but completely missed the ones relating to radians and degrees. goes of to clean up some scripts...
              • chrisglasierC
                chrisglasier
                A quick pre-dinner try I get this with 90 deg rotation around X :
                Now off to eat!
                • chrisglasierC
                  chrisglasier
                  A quick pre-dinner try ...
                  ... failed because I made
                  t = selection.transformation, when it should be something related to vector3D ??
                  Also I don't understand the difference/relationship/source of zaxis and (Z_AXIS).
                  Perhaps I have made it too confusing both here and also in this previous topic.
                  All I want to do is iterate through model entities to make each component and group a javascript array element, each with its own array of name/value couplets at least for xPos, yPos, zPos, xRot, yRot, zRot. The xyz business seems OK, where in an animation, for example, I can compare one entity's position with a new position to determine the translation. I want to do the same with rotations around each of the axes.
                  Sorry if I'm being rather painful, but I am sure a good result will help the mantra below.
                    Jim
                    Chris,
                    Z_AXIS, X_AXIS, and Y_AXIS are constants that are the vectors of SketchUp's global axes.
                    Here's a screenshot of a cube rotated 45 deg around the Z axis.
                    And I just noticed I said to use .degrees in an earlier post, sorry; it's .radians.
                    • chrisglasierC
                      chrisglasier
                      @jim said:
                      Chris,
                      Jim I think the fog maybe clearing ... many thanks ... chris
                      • chrisglasierC
                        chrisglasier
                        I made a skp, rb, html set to test what I understand so far about transformations on a 3x4x5 metre group. If you want to try it out temporarily unzip the files to your plugin directory.
                        transformations.zip
                        Here is a clip of it showing a group rotating around each of the axes in turn:
                        [flash=425,344:32q3oq38]http://www.youtube.com/v/aXxkHu7gSv4[/flash:32q3oq38]
                        The rotations are made with:
                        tr = Geom::Transformation.rotation(Geom::Point3d.new(ent.bounds.center), rv, theDegrees), where rv is the axis,
                        and the angle_between values with:
                        (t.xaxis.angle_between X_AXIS).radians
                        • same for y and z.
                        From this, I gather if the angle_between values returned are 0-180-180, the group has been turned by 180 deg on the X_AXIS; and if 0_90_90, the group could have been turned 90 or 270 (-90) degs on the X_AXIS; and the same for the angle_between values for the other axis rotations.
                        The second clip shows the application of different series of rotations:
                        [flash=425,344:32q3oq38]http://www.youtube.com/v/TFAnDrHXaIg[/flash:32q3oq38]
                        Screenshots of rotations providing angle_between values of 90-90-90 shows there is either something fundamental missing or perhaps that an entirely different method is appropriate.
                        Any suggestions about this most welcome...
