    Best tree generation system
    27 Posts 13 Posters 6.7k Views 13 Watching
      Starlex
      Hi!
      I'm searching for the best tree gen.
      Till this moment, I find 3 systems: Onyx Tree, Xfrog and Speed Tree
      According to the web info first two was released in 2003...
      So, anyone, who was work with this apps, please give your opinions)
        l.frisken
        you could try component spray (sketchup plugin). It might make your model run slowly though, depending but if you want to render it then you can use the instancing funtion for indigo or kerkythea exporter.
        • X Offline
          xrok1
          l.frisken, i think he wants to make a tree not spread them around. that will be the next question. 😄
            Ivy is also a very cool vegetal generator ☀
            • soloS Offline
              Xfrog is great but for use in SU no bloody way!!!, unfortunatly SU has a poly limit so any, I repeat any treee generator will not work great in SU.
              Onyx, is also good but read the EULA carefully, and it too is too heavy for SU.
              Speedtree I cannot coment on as I have never used it.
              Vue tree generator works great too, and also converted to SU will kill your speed.
              I have heard great reviews of the Renderplus tree generator however, but I've not really tried it.
              • X Offline
                xrok1
                carrara has a pretty good tree generator, but i have c5pro. i don't know if the new carrara lite or free or whatever its called has the tree generator. anyone know?
                i went to check and it turns out that its 'carrara express' and its not free ($99) and it does generate trees and landscapes. i'm pretty sure it was free before but it dosn't seem to be now??
                  tomsdesk
                  Check out http://arbaro.sourceforge.net/ it's easy to learn (if you like to play a bit) and does it's thing pretty fast; exports DXF, OBJ, and povray (whatever that is); and is completely FREE! But: it will kick SU in the gut bigtime just like the others. (Which is why I started making the 2.5d varieties :`)
                  2.5D Trees & Shrubs!
                    Starlex
                    Thanks to all)
                    So, I was tryed Onyx Tree... I can say, that its generate trees with about 100-150K polygons on each. And there is 'minimize' function, that reduce number of polygons to 20-40K
                    I was launch SU with imported model, and it start to work very slow (AMD 5200+, not the best for the 3D, but...)
                    I'm working with landscape modelling, and I need realistic trees very much
                    So, what should I do? Maybe settling in 3Dsmax?
                    Or I have to try SU with imported tree on quad-core processor? Will it help?
                      remus
                      If you need to use high poly trees your better of doing it another app, sketchup whimpers and dies in the face of high poly trees.
                      • EdsonE Offline
                        Edson
                        have you tried RpTreeMaker?
                        http://www.mahfuz.arq.br
                        • H Offline
                          henrietta
                          And here's another one:
                          http://hothouse3d.com
                          • david_hD Offline
                            david_h
                            Is this Hothouse 3D a Freebie Program? I didn't notice any details about pricing or whether or not this is a trial?
                            Thx,
                            D
                            • H Offline
                              henrietta
                              Hi David. It's a freebie for the foreseeable, but never say never:)
                                Dryad free
                                http://dryad.stanford.edu/images/gallery/image1_big.png
                                  Frecle free
                                  http://www.frecle.net/treed/treed_screenshot04_autumn.jpg
                                  • RichardR Offline
                                    Richard
                                    Frenchy - YOU DA MAN!
                                    [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                      You too Richard, you too ! 😉
                                      This curiosity for you 😄 Not sure it's work if you have not 3DCoat but...
                                      http://www.3d-coat.com/forum/index.php?s=78df26c2676dbaffc050c56a4bc2108e&act=attach&type=post&id=480
                                      http://www.3d-coat.com/forum/index.php?act=attach&type=post&id=510
                                      • david_hD Offline
                                        david_h
                                        Frecle free
                                        So I went to this link but I couldn't see where one actually downloads the software! it was a link to a forum that links to another forum . .etc etc? any help?
                                        Thx,
                                        D
                                          Hum hum 💚
                                          You don't see the link following the images? 😒
                                          Maybe glasses is needing 😉
                                          • david_hD Offline
                                            david_h
                                            No. . . I didn't see that. Merci.
                                            ps. I do wear glasses. . .. apparently it's time for a perscription change.
