    Rogue's W.I.P's!
    922 Posts 55 Posters 434.5k Views 55 Watching
    • B
      BLANK
      I've been working on some wheels lately and I thought it might be time to (place Obama reference here). I noticed that you make wheels using a 100-faced circle ๐Ÿ˜ฎ. What I did is double the standard amount to 48. I could try 96, but size is an issue.
      Here's an example I did for Alex's Viper:
      ![Everything except for the brake pads and the disk vents were "enhanced"](/uploads/imported_attachments/ENwC_2.png "Everything except for the brake pads and the disk vents were "enhanced"")
      And yes, first attempt. ๐Ÿ˜„
      If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
      • F
        FioranoJC
        Yo Shams,
        WTF MAN ๐Ÿ˜ฎ
        ๐Ÿ˜Ž So cool, So good, So pro style! Im busy with this:
        Ferrari Tipo 500 F2 ( Old ferrari Racer )
        http://img8.imageshack.us/img8/6721/tipo500tr2.png
        Just started with the wheels caus theyre the most important thing of that car.
        Butta, after seeing your 46 circle.. mmm Intressting. I might start all over again but after im finished with this wheel.
        • Roguer1R
          Roguer1
          Its good to see people talking about wheels for once. I have been making them for ages now and people only seem interested in the next car, usually my wheels hint towards that as I also try to make my wheels first or when I get stuck in a model (yes I often get stuck)
          Any way, that Viper wheel is looking great, very detaild and clean.
          I often use 100 sides because I usually make 5 spoke wheels and I cant be bothered making a new tyre for every one.
          @fioranojc said:
          Im busy with this:
          Cant wait, although if its done with'n the next few weeks I wont be able to see it. ๐Ÿ˜ข
          Find all my models on the 3D Warehouse
          • Roguer1R
            Roguer1
            It looks interesting but I think I'll just try to stick with the 5's I know. The Ford inspired ones.
            Also feel free to catch up on my image uploads on my website
            http://rogueautomotivedesign.webs.com/apps/photos/
            • Roguer1R
              Roguer1
              Here is a little update for the Trojan Cobra:
              • Roguer1R
                Roguer1
                I have done a little more on my Mach II
                I have also found a picture of another similar Ford Concept, only picture I can find...
                more info: http://www.ponysite.de/Mach1history.htm
                • Roguer1R
                  Roguer1
                  Now that I'm back, here is some more stuff
                  My first model made in SketchUp 7 Pro
                  http://sketchup.google.com/3dwarehouse/details?mid=bd8b8dae85745dc61d7499a6ca2305ee
                  • Roguer1R
                    Roguer1
                    Im getting no discussions here again....
                    New model:
                    http://sketchup.google.com/3dwarehouse/details?mid=77cc8819b15c187f308db5b674b9975c
                    • MarianM
                      Marian
                      Well, your work is good, we all know that, not much to discuss about that, except if you have an idea or you want advice.
                      • Roguer1R
                        Roguer1
                        Thanks Marian
                        Here is another wheels, its from the 2010 Ford Taurus SHO
                        http://sketchup.google.com/3dwarehouse/details?mid=89098b35adf27910cac6f4f313ef6248
                        This has been one of the hardest wheels I have made so far
                        • RayOchoaR
                          RayOchoa
                          maybe you could sho us how you make those cool wheels?
                          CaR DeSiGnS bY mE
                          http://ray-ochoa.com
                          • Roguer1R
                            Roguer1
                            I did try to make a video tutorial using this complicate wheel but it took 4 hours and I didnโ€™t have enough space to store the large file on my HDD...
                            It was recorded in HD.
                            I also ran into quite time consuming problems so it turned out a mess.
                            I will still try to make a video tutorial next time I make a wheel or if I could figure out a good way to, a SketchUp tutorial.
                            • Roguer1R
                              Roguer1
                              Just a little update on the Cobra, no images this time (under wraps)
                              Work on base model
                              -Interior started and it is going well, a few complications but looking good
                              -Exterior still not finished, underbody just started
                              -Estimated total poly's: 100,000-ish
                              • P
                                puck
                                Still amazed by the results you've managed to get. I'm beginning work on an Audi A3 today which is my first attempt at a car. I will post when I have something worth looking at.
                                Keep up the good work, I think when people don't speak it's because jaws have dropped at some of the things you've done here!
                                Puck
                                • Roguer1R
                                  Roguer1
                                  Thanks a lot Puck
                                  I would like to see what happens with your A3, best of luck.
                                  • RayOchoaR
                                    RayOchoa
                                    All your models are very cool ๐Ÿ‘
                                    How bout trying to make a concept car completely from your imagination and make it "real" by rendering or something. ๐Ÿ˜„
                                    I was looking at your cars earlier and i saw that range stormer car. ๐Ÿ˜ฎ Dude!! Freakin awsome. So much detail and everythin
                                    CaR DeSiGnS bY mE
                                    • B
                                      BLANK
                                      Do I see a dashboard in that Taunus? Hmm... ๐Ÿ˜„
                                      • Roguer1R
                                        Roguer1
                                        Hmm, doesnโ€™t sound like a bad idea but a lot of the concept cars I design on paper are very complicated.
                                        I have a lot of modeling to do at the moment but I will surly get around to it one day.
                                        Yes, you do ๐Ÿ˜›
                                        I have done a bit of work on the interior a long with the exterior. Did anyone wonder why I showed the back this time instead of the front?? Itโ€™s because the already awesome looking front is being re-built. Donโ€™t worry, itโ€™s not changing much, just a few minor details will be changed. Itโ€™s mainly just a re-build to fix a few bits of poor mesh work and make it look realistic.
                                        • Roguer1R
                                          Roguer1
                                          OK, im getting a little board...
                                          http://sketchup.google.com/3dwarehouse/details?mid=e6f92c08e37d286fc811557dfc014b14
                                          If you read the model description youโ€™ll notice that I have said I will also make the actual Taunus 4 spokes wheels which are quite similar.
                                          What do you think?
                                          • Roguer1R
                                            Roguer1
                                            Another wheel
                                            Error 404 (Not Found)!!1
                                            (sketchup.google.com)
                                            Please download and take a look at the changes from the old D-010 to 25 and 26 before you pass judgement. I have done a hugh amount of work on all three models. The D-010 has basically been re-modeled and, although the 25 and 26 are based on the 10, they are both unique and vastly improved. The 26 has taken me about 3 hours to model so, as you can tell, itโ€™s not a simple task.
                                            So what do you think?
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
