    Rogue's W.I.P's!
    922 Posts 55 Posters 366.6k Views 55 Watching
    • Roguer1R Offline
      Roguer1
      Here is a little update for the Trojan Cobra:
      Find all my models on the 3D Warehouse
      • Roguer1R Offline
        Roguer1
        I have done a little more on my Mach II
        I have also found a picture of another similar Ford Concept, only picture I can find...
        more info: http://www.ponysite.de/Mach1history.htm
        • Roguer1R Offline
          Roguer1
          Now that I'm back, here is some more stuff
          My first model made in SketchUp 7 Pro
          http://sketchup.google.com/3dwarehouse/details?mid=bd8b8dae85745dc61d7499a6ca2305ee
          • Roguer1R Offline
            Roguer1
            Im getting no discussions here again....
            New model:
            http://sketchup.google.com/3dwarehouse/details?mid=77cc8819b15c187f308db5b674b9975c
            • MarianM Offline
              Marian
              Well, your work is good, we all know that, not much to discuss about that, except if you have an idea or you want advice.
              • Roguer1R Offline
                Roguer1
                Thanks Marian
                Here is another wheels, its from the 2010 Ford Taurus SHO
                http://sketchup.google.com/3dwarehouse/details?mid=89098b35adf27910cac6f4f313ef6248
                This has been one of the hardest wheels I have made so far
                • RayOchoaR Offline
                  RayOchoa
                  maybe you could sho us how you make those cool wheels?
                  CaR DeSiGnS bY mE
                  http://ray-ochoa.com
                  • Roguer1R Offline
                    Roguer1
                    I did try to make a video tutorial using this complicate wheel but it took 4 hours and I didn’t have enough space to store the large file on my HDD...
                    It was recorded in HD.
                    I also ran into quite time consuming problems so it turned out a mess.
                    I will still try to make a video tutorial next time I make a wheel or if I could figure out a good way to, a SketchUp tutorial.
                    • Roguer1R Offline
                      Roguer1
                      Just a little update on the Cobra, no images this time (under wraps)
                      Work on base model
                      -Interior started and it is going well, a few complications but looking good
                      -Exterior still not finished, underbody just started
                      -Estimated total poly's: 100,000-ish
                        puck
                        Still amazed by the results you've managed to get. I'm beginning work on an Audi A3 today which is my first attempt at a car. I will post when I have something worth looking at.
                        Keep up the good work, I think when people don't speak it's because jaws have dropped at some of the things you've done here!
                        Puck
                        • Roguer1R Offline
                          Roguer1
                          Thanks a lot Puck
                          I would like to see what happens with your A3, best of luck.
                          • RayOchoaR Offline
                            RayOchoa
                            All your models are very cool 👍
                            How bout trying to make a concept car completely from your imagination and make it "real" by rendering or something. 😄
                            I was looking at your cars earlier and i saw that range stormer car. 😮 Dude!! Freakin awsome. So much detail and everythin
                            CaR DeSiGnS bY mE
                              BLANK
                              Do I see a dashboard in that Taunus? Hmm... 😄
                              If only the Yakuza had heard of Australia... [url=http://sketchup.google.com/3dwarehouse/details?mid=cd46471677a3e490b8f4e95477ed5df:21uuz2ul]Ford Falcon sedan conversion[/url:21uuz2ul] [img:21uuz2ul]http://lh5.ggpht.com/_DXlDhsgmn6Q/S2Qi2PU4IJI/AAAAAAAAAuE/AqSICmCNiS4/s800/Untitled-1.jpg[/img:21uuz2ul]
                              • Roguer1R Offline
                                Roguer1
                                Hmm, doesn’t sound like a bad idea but a lot of the concept cars I design on paper are very complicated.
                                I have a lot of modeling to do at the moment but I will surly get around to it one day.
                                Yes, you do 😛
                                I have done a bit of work on the interior a long with the exterior. Did anyone wonder why I showed the back this time instead of the front?? It’s because the already awesome looking front is being re-built. Don’t worry, it’s not changing much, just a few minor details will be changed. It’s mainly just a re-build to fix a few bits of poor mesh work and make it look realistic.
                                • Roguer1R Offline
                                  Roguer1
                                  OK, im getting a little board...
                                  http://sketchup.google.com/3dwarehouse/details?mid=e6f92c08e37d286fc811557dfc014b14
                                  If you read the model description you’ll notice that I have said I will also make the actual Taunus 4 spokes wheels which are quite similar.
                                  What do you think?
                                  • Roguer1R Offline
                                    Roguer1
                                    Another wheel
                                    Error 404 (Not Found)!!1
                                    (sketchup.google.com)
                                    Please download and take a look at the changes from the old D-010 to 25 and 26 before you pass judgement. I have done a hugh amount of work on all three models. The D-010 has basically been re-modeled and, although the 25 and 26 are based on the 10, they are both unique and vastly improved. The 26 has taken me about 3 hours to model so, as you can tell, it’s not a simple task.
                                    So what do you think?
                                    • RayOchoaR Offline
                                      RayOchoa
                                      4 spoke are nice. I like how you make them look like actual real life rims. 👍
                                      CaR DeSiGnS bY mE
                                      • Roguer1R Offline
                                        Roguer1
                                        Thanks Ray.
                                        Its 4 a.m and im still going.
                                        At this rate SketchUp will be illegal soon... 😉 its addictive!
                                        • Roguer1R Offline
                                          Roguer1
                                          That is an astonishing looking paint job and that wing just tops it off.
                                          The render looks very crisp; you must be spending a lot of time and effort perfecting the textures and a have quite high performance computer to get results like that.
                                          My renders always turn out really speckled with fireflies even after 10 hours with fryrender. I need a much better computer. I know my model is bottom of its line so I can’t expect that much.
                                          Once again, model is looking great, I can’t wait to see it finished.
                                            BLANK
                                            Haha. Not quite... Here's the shocker:
                                            I use Vista with a 512MB card.
                                            The Artega is done; just a few flaws left. I'll upload it this weekend.
                                            Oh and I'm thinking of doing some render work for a few weeks. I'm going to start with the Maverick GT. Should I post them here or send it to you by email?
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
