    [Plugin] Smoothstep Animation
    80 Posts 50 Posters 106.0k Views 50 Watching
      Matt666
      @pixero said:
      Sketchup.send_action "pageDelete:"
      A confirmation message box opens every attempt to delete a scene...
      Frenglish at its best !
      My scripts
      • PixeroP
        Pixero
        Well...lets hope Whaat finds a trick to fool SU to delete the scenes without SU knowing what happened... 😒
        Is
        entities.clear!
        not working either?
        • K
          kwistenbiebel
          Hi Whaat,
          Would it be a sh*tload of work for you to have this plugin make default scene tabs after smoothing the animation ? (needed for render engines)
          The current method (cameralines.rb,F-Spline bezier,Flightpath (or SU-animate) is kind of tedious.
          Your smoothstep animation ruby would be an easier 'out of the box solution' when it can create a scene tab animation.
          If it is a lot of work...maybe commercial?
          • W
            Whaat
            @kwistenbiebel said:
            Hi Whaat,
            I am curious. Which render engines are able to automatically render all scene tabs? I assume you are not manually rendering each scene tab when you are creating these types of animations.
            • K
              kwistenbiebel
              Vray and Fryrender can render a scene tab animation.
              For instance, if you have 1 scene tab per animation frame, you set the SU transition time to 1 second.
              In the Vray/Fry panel, you set 1 fps.
              That way, Vray/Fry will render each scene tab automatically when hitting the render button.
              I thought Skindigo can do this as well? (confused)
                steelers05
                yeah im with biebel on this one.. that would be great if you could make something like that
                  Dan
                  Thanks for yet another great plugin, Whaat!
                  Me too I did a very quick test and all seems to be ok.
                  I have to ask you a little change to the script, if possible: can you make it to number the exported bitmaps like "name00001.jpg", "name00002.jpg", instead of "name0.jpg", "name1.jpg", etc. to make the conversion to avi program to read them in the right order?
                  Thanks again!
                  • FletchF
                    Fletch
                    I second KB and Steeler's request, Whaat... you still thinking about this?
                    Fletch
                    • Z
                      zeal
                      Thank you for sharing 😍
                      • K
                        kwistenbiebel
                        Hi Whaat,
                        I needed to add that in a lot of cases an animation spread over X scene tabs according to X animation frames (1 scene tab per animation frame) can be an advantage.
                        For instance, when you have 'face me' components. Both Vray and current Skindigo won't render the face me components correctly (they will not face the camera), unless the animation consists of as many scenes as there are animation frames.
                        I think if someone of the ruby masters would be able to make a decent and easy to use smooth animation plugin like that, we don't need to learn the dinosaurs apps to get some decent PR animations.
                        Currently I use the combo of rubies described above and it works , but it is too tedious to do in a daily workflow.
                        • K
                          kwistenbiebel
                          @fletch said:
                          SU2KT lets you export animations via scene tabs, and can include or exclude face-mes depending on your desired outcome.
                          Yes, I hear positive things about a Kerkythea animation workflow.
                          It is good though to have a freedom of choice on render engines when it comes to animation, so a built in smooth scene tab animation in Sketchup would be cool.
                          Since Google doesn't seem to have a go at it (animation is untouched in 3 versions), the ruby masters might be are our only option here.
                          Whaats Smoothstep plugin is a good start, but it doesn't play with the render engines yet.
                          • PixeroP
                            Pixero
                            I still thinks my idea in my post on page one in this thread is both doable and would be the best way of using keyframes and inbetweens in SketchUps current animation implementation. That way you could go back to only the keyframes if you want to edit the animation and still get a scene per frame for rendering the animation.
                            • FletchF
                              Fletch
                              Fletch
                              • facerF
                                facer
                                Help Note for use of:
                                smoothStepAnim.rb - 0904_05apr_jpeg to avi
                                Working with image sequences - using VirtualDub to convert jpeg images to avi.
                                Following on from Whaat's usage notes item #3:
                                smoothStepAnim.rb
                                by Whaat on Tue Oct 07, 2008 4:18 am
                                Usage:
                                3) Plugin can export single frames only. The images must be joined into a movie format using other software (eg. VirtualDub)
                                VirtualDub
                                http://www.virtualdub.org/blog/pivot/entry.php?id=34
                                Time to actually post something for users and not just developers.
                                To reading a series of numbered images as a video stream
                                use File > Open video file... and select the first image. VirtualDub will automatically step the filename and find any sequentially numbered frames after the starting file. You can open BMPs and TARGA files this way. Starting with VirtualDub 1.6.0, you can also sequential JPEGs and single files. In 1.6.2, you can also open non-interlaced PNG. Once the sequence has loaded, use Video > Frame Rate to set the correct frame rate for the sequence.
                                To exporting a video segment as a sequence of numbered images
                                on disk in VirtualDub, use File > Save Image Sequence. What you may not know is that nearly all of the regular video processing modes are still enabled in this mode. This includes video format, frame rate decimation/conversion, filtering, etc. modes. In particular, if you only want to write out every fifth frame in the video, simply set frame rate decimation to "every 5" and you will only get 1/5th of the frames. Similarly, if you are writing out BMPs, you probably want to use no video compression and a normal video format such as 24-bit RGB. (That VirtualDub allows you to write out something silly like MPEG-4 compressed "BMPs" is actually a misfeature that I need to fix.) For the most part, though, what you see in the preview is what will get written out to disk as images.
                                Side note:
                                It isn't well known, but VirtualDub uses the exact same pipeline for all of its rendering operations. That includes AVI, WAV, and image sequence output, as well as... preview. The primary differences are whether certain outputs are disabled and whether the frame limiter is enabled. I spent a long time ago optimizing the pipeline to overlap I/O and CPU utilization and reduce synchronization overhead for better real-time preview; when you save to disk, the limiter is kicked out and you get the benefits of that work in faster rendering.
                                20 comments | Dec 30, 2004 at 20:05 | default
                                Additional topic - jpeg images to avi - questions
                                can be viewed at:
                                pmolson posted 2007 Jun 15 00:14
                                "photo slide show" (converts jpg frames to avi)
                                • facerF
                                  facer
                                  I support Dan's suggestion above (10 Feb 09) about numbering image files on export.
                                  I did a small test which resulted in 160 frames exported. I had to re-number
                                  61 frames to allow VirtualDub to read them in correctly. This would make a typical
                                  building file unmanageable for video software as VirtualDub.
                                  I have attached my CHECK Note for anyone who has not tried it before.
                                  This is my process for a SunTool Video TEST.
                                  Process:
                                  The following video used these key SketchUp plugins:
                                  1. SunTool - http://tx.technion.ac.il/~arrguedi/SunTools/dwnld_after_reg/STdwnld.htm
                                  2. Scenes Transition Times - scenes_transition_times.rb - by http://morisdov.googlepages.com
                                  3. Export smooth Animation - smoothStepAnim.rb - by Whaat
                                  Process used on a TEST SketchUp Model with SunTool set for the month of Sept 21
                                  1. Jpeg images of views are exported using Export smooth Animation. These have to be re-numbered as they are not numbered to maintain the "number width" as required. For example images0035 image0036 etc when 1000 frames are exported. This is a nuisance but it has been pointed out by Dan to Whaat the Ruby programmer. Hopefully this will be addressed in a future update.
                                  2. Scenes were created for:
                                    scene1. Sept 21 - 0800 (start)__scene2. Sept 21 - 0900
                                    scene3. Sept 21 - 1200__scene4. Sept 21 - 1500 (end)
                                  These correspond to shadow studies for one of the months and dates set by the local town planning authority hear in Melbourne.
                                  Layers are used to turn off the sun location graphics produced by SunTool for times not in the scene. Therefore each SCENE shows only the sun location for
                                  the time corresponding to the shadow turned on.
                                  1. Transition times are set using the Scenes Transition Times plugin. This plugin allows quick comparisons VISUALLY for different time settings for each scene.
                                  2. Exported jpeg images using Export smooth Animation and assign all to one folder - CHECK number sequencing to maintain "number width" (refer note above).
                                  3. Using VirtualDub:
                                    1.File>open video file
                                    select files of type - image sequence >select first file > open
                                    Files are imported and images should display in VirtualDub window.
                                    1. Video > compress (compress file size)
                                    2. File > save as AVI ( compressed AVI)
                                      1. Video Completed.
                                    Stray
                                    I made a small change to Whaat's code so it pads the filenumbers with leading zeroes, I hope you don't mind.
                                    Just change this line (line 107):
                                    @image_path=File.join(@export_path,@filename+"#{@frame}"+".#{@format.downcase}")
                                    to this:
                                    @image_path=File.join(@export_path,@filename+"#{@frame.to_s.rjust(10, '0')}"+".#{@format.downcase}")
                                    Thanks for the plugin Whaat! Best regards.
                                    A very slightly modified version of Whaat's Smoothstep Animation script that pads the output filenames with zeroes for better sorting.
                                      driven
                                      I've been trying this out and had two very different results re: output quality (they're both up on youtube, link to one here...
                                      http://www.youtube.com/watch?v=YMRfjRsIQ7g&layer_token=9015d6617d71c051
                                      the first was made was made manually from 12 layers containing 12 instances (re-named) at 15º of rotation, made using xformclone.rb (fantastic...)
                                      I tranfered this at (640x480 12 fps jpg >1) into iStopmotion so I could remove the 6-8 dead frames between each layer swop, I also batch cropped, and did a half speed test by dropping more frames, I'm very happy with the results...
                                      the 2nd was a linear motion test with a single incident component (but much hire poly-count), on only one layer. Steps were achieved using mover.rb and tying the object to and the green axis with the rotate tool, scroll wheel clicks were used for spacing... the movement look acceptable on screen but SU frose when transferring at the previous settings... I turned the frame rate up... and then down... crashed SU... I removed xformclone and standard views just in case, sill frose during transfer, I then stripped out the clip, used your default settings and finally got a set out..
                                      Each try did output jpgs, all of equally bad quality, any thoughts?
                                      I tend to think that more organised layering(with sub folders) will always give a better quality result, if you take out the lag or play to it.
                                      I haven't tried out putting with proper_animation.rb yet as I needed to get my head around the basic functionality of using scenes first.
                                      Anyway I was very impressed with output quality on the first one and for any mac user iStopMotion and iMovie make post-production and posting to YouTube a breeze..
                                      cheers
                                      16KB
                                      12KB
                                        rickymon
                                        Hey guyz
                                        I know this is an old thread, but just for you to know...
                                        Was looking for a plugin to animate objects, and I found Properanimation.rb by morisdov
                                        This is a very cool plugin but did not have any way to export, native SU export engine did not support it. There are hughe threads about this issue, other people was considering to make screencapture videos, or get fancy external render engines.
                                        But guess what...?
                                        Smoothstep Animation not only exports smooth camera scenes, it also recognizes all Properanimation.rb animations.....!!!!
                                        So if you are looking for a cool tool to animate objects, try both plugins
                                        Properanimation.rb + SmoothstepAnim.rb
                                        Uploading utube
                                        http://www.youtube.com/watch?v=UL6tnTvphAE
                                        Done
                                        • jcdbJ
                                          jcdb
                                          Created with Smoothstep Animation
                                          http://www.acustombuilder.com
                                          • romboutR
                                            rombout
                                            @rickymon said:
                                            Hey guyz
                                            But guess what...?
                                            Uploading utube
                                            Done
                                            but how did you get to export all geometry, cause i thought he said i could only export images???
                                            • 2 / 4
