    Driving Dimensions
    extensions
    70 Posts 21 Posters 31.6k Views 21 Watching
      peweuk
      @dmitry ushakov said:
      But again, the support of components is in our 'todo' list.
      Something else to look forward to.
      Driving Dimensions inside Dynamic Components would be very powerful.
        You can always "Save as" your component, work on it as a plain SU file then reload (well, I know, workaround... 😒 )
          Dmitry Ushakov
          Hello everybody!
          Driving Dimensions version 0.4 was released today. This plugin for SketchUp 6/7 runs on Windows 2000/XP/Vista.
          So what's new in 0.4?
          • a new kind of driving dimensions: vertex-face distance,
          • non-rigid arc curves,
          • improved Undo functionality
          Models with arcs (like one recently presented by peweuk in this thread) are now solved correctly: you can change any distance. As an example I give you an animated GIF with a triumphal arch - you can edit everything in this model with parameters.
          Triumphal Arch with Driving Dimensions
          Find this and other sample models at http://drivingdimensions.com/SketchUp/samples.php.
          Download Driving Dimensions 0.4 at http://drivingdimensions.com/SketchUp/download.php.
          Read full press release at http://drivingdimensions.com/news.php?num=5.
          Enjoy our plugin and feel free to share your comments or suggestions with us!
          Sincerely yours,
          Dmitry Ushakov
          Director of Product Management
          LEDAS Ltd.
          http://www.DrivingDimensions.com - parametric plugins for SketchUp and Rhino
          • MALAISEM Offline
            MALAISE
            Small Post to thank you Dmitry to share that plugin quite useful 👍
            MALAISE
            • X Offline
              xrok1
              😍 I've been waiting for this since the first time I used sketckup!!!!!!! 😍
              THANKYOU
              if i had 1 request it would be for equations eg. dim1=dim2/2 or dim1=dim2+dim3*2 etc... although the dimensions would need to be named for this to be possible; but then it would truly be THE #1 architectural/design plugin for Sketchup!!
                Dmitry Ushakov
                MALAISE, xrok1,
                Thank you for the interest to our plugin!
                Support of engineering equations linking dimension parameters is one of our short term objectives.
                Sincerely yours,
                Dmitry Ushakov
                LEDAS Ltd.
                • X Offline
                  xrok1
                  😍 SWEET 😍 👍
                  • Mike LuceyM Offline
                    Mike Lucey
                    Thank You Dmitry for a great plugin. I can see lots of ways this can be used to great effect in the Design Process.
                    I must compliment you on your excellent response times also. Its great to have this 'friendly' attitude shown here on SketchUcation.
                    I'm looking forward to trying out Driving Dimension as soon as time permits, BTW will it work with Mac? If not we Mac users can always switch to Win via Bootcamp.
                    Mike
                    • I Offline
                      ilay7k
                      Dmitry, thank you for update!
                      Also Dmitry or anybody from SU dev.team, can add expression of DD(Driving Dimensions) to library of dynamic-component's expressions/formulas?
                      Into Russian:
                      Спасибо еще раз! Дмитрий, вы наверно видели уже о вводе формул в параметры динам.компонентов, можно ли туда добавить ваши выражения плуга для управления компонентом?
                      • RayOchoaR Offline
                        RayOchoa
                        excuse me but can you use this on more complex things like maybe Automobiles and things like that?
                        CaR DeSiGnS bY mE
                        http://ray-ochoa.com
                          Dmitry Ushakov
                          Hello Mike,
                          Thank you for the interest to Driving Dimensions!
                          We will definitely port our plugin to Mac OS, but first we have to release a Mac version of our geometric solver LGS 3D, which is the base for the plugin. We are already working on that.
                          Sincerely yours,
                          Dmitry Ushakov
                          LEDAS Ltd.
                            Dmitry Ushakov
                            Dear ilay7k,
                            Thank you for the interesting idea of the integration of Driving Dimensions with Dynamic Components! We have no particular plans for that yet, but in the forthcoming versions of our plugin one will be able to use variables and formalas when specifying values of driving dimensions.
                            Sincerely yours,
                            Dmitry Ushakov
                            LEDAS Ltd.
                              Dmitry Ushakov
                              Why not? The only limitation of our plugin is that it cannot be used to dimension grouped entities (ones placed inside components).
                              But if one speaks about automotive design, he/she usually means things like class A surfaces or at least the possibility to specify G0/G1/G2 connections between curves and surfaces. Current version of Driving Dimensions does not support them. In the forthcoming versions we plan to support a tangency constraint with arc curves.
                              Sincerely yours,
                              Dmitry Ushakov
                              LEDAS Ltd.
                              • EdsonE Offline
                                Edson
                                as usual, windows only!
                                http://www.mahfuz.arq.br
                                • X Offline
                                  xrok1
                                  and there's a prime example of why i don't own a MAC.
                                  it could be a nuclear powered ,thermo dynamic ,speed of light*2 ,quadruple core ,16 pipeline ,32gig of genetically enhanced organic ram computer ,that can read my thoughts but if you can't get the software?????? 👊
                                    Mike Lucey
                                    For the Intel Macs its just a matter of switching over to SketchUp via Bootcamp .... a bit mesy but no big deal 😉
                                    Mike
                                    PS: Am I being smug 😄
                                    • EdsonE Offline
                                      Edson
                                      Mike
                                      or via Fusion/Parallels, which is even easier... 😉 😉
                                        Don't be impatient, Edson!
                                        • X Offline
                                          xrok1
                                          @dtrarch said:
                                          Dmitry
                                          2d lines can be used to generate 3d walls and as reference for plan development too.
                                          (Also one can convert lines to construction lines and vice-versa with existing scripts for grid and reference use.)
                                          Parametric line adjustment when developing design schemes is very useful.
                                          A constraint to retain the angle at corners would be helpful in this regard.
                                          (a lock corner/angle/geometry function perhaps)
                                          dtr
                                          could you elaborate on this, i've been looking for a way to do this.
                                          • PixeroP Offline
                                            Pixero
                                            Is anyone able to use it on groups/components or inside a group/component?
                                            (I almost never have ungrouped parts in my models.)
                                            • 3 / 4
